![]() | Home > General > Fuel Con |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Full service first - genuine parts from Dan@Duckworth on here:
Fuel leak when driving? |
Good quality oil.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
your service might have done a proper reset on the fuel consumption computer so the best way to find a 'real' average mpg is to do a tank to tank fill... ... - .- -.
I recommend fuelly - it will show you real world figures. Land Rover Addict
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Mine has dropped too, not quite sure what thats all about. |
...more strain on the engine because of more use of the a/c ? ... - .- -.
I'm not sure Stan, i haven't used it this week when its been pastie boy hot. Been on the ped. Just generally the mpg has dropped recently |
dont engines run better with cool air for combustion rather than hot...could be the reason maybe ian.. ... - .- -.
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 ![]() ![]() ![]() |
My consumption dropped a few months ago. Problem was a seized brake calliper. No longer FF owner but still interested. Present car Jaguar XE
Fuel consumption goes up in the winter months |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 ![]() ![]() ![]() |
stan... does the cold dense air not just give better combustion and a bit more power due to a better burn? hence the reason that jap car tuners fit large front mounted intercoolers to ram as much cold air into the system as possible.
you could be correct stu, but if the combustion is more efficient then you need less fuel to get to required speed.. ... - .- -.
good point well presented!!!
