![]() | Home > Maintenance & Mods (L322) > TD6 Gearboxes - how robust is yours? |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 ![]() |
Mine failed at 70 k but was replaced under warranty. Tip- Get a warranty (warranty direct) |
piecost76 Member Since: 19 Jul 2010 Location: Nr Sevenoaks, Kent Posts: 296 ![]() ![]() |
Mine went at 112k miles. PO had it refurbed at a cost of £2k! |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Mine has just turned 60k and from reading on this forum I have decided, if it ain't broke don't fix it.. Too many stories of faults after oil and filter changes to the gearbox. Previously..
I8A Jeep Member Since: 13 Apr 2011 Location: Cape Town Posts: 12 ![]() ![]() ![]() |
Thanks guys. I'm also in two minds whether to do the oil change or not. at the moment it feels to run fine, certainly no jerking or failure to take up drive. perhaps the 'if it aint broke....' approach is best option. |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Took ownership of mine with 126k on the clock so dropped oil and filter and replaced with genuine filter and fluid. After a further 3 months dropped and changed the fluid again, now got 142k on the clock and shes sweet as a nut |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 ![]() ![]() ![]() |
See my previous post about faulty filters But if its good I would just check the oil level if its wear in the valve block changing the oils will not help.
Reformed Member Since: 09 Oct 2010 Location: South Posts: 471 ![]() ![]() |
Let's hope so, as I drive mine like an old fart! And I'm young! |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 ![]() ![]() ![]() |
I went through 5 td6 gearboxes in 120,000 miles.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3765 ![]() ![]() |
were these 5 recon or new boxes? there must have been a fault, or they were not installed and filled with oil correctly, for two gearbox's to last 5k miles there is obviously an issue somewhere and I don't think that can be put down to LR. Yes failures at around 100 to 120k miles is well documented, but 5 boxes in the same period is just wrong. |
I slot mine into S but use it more like a manual to force 5th and lock up when pootling at about 30-35 where it wouldnt normally allow lockup |
Never driven with the S function - I have tried it and it does work though and the vehicles never towed - so that could be the reason why its standing up to the 140k+ mileage |
I suspect that a few of the TD6 gearbox issues relate to a driving style that simply cannot be matched by a TD6 gearbox due to the demands put on it by a heavy Range Rover that it was not 100% designed for.
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16315 ![]() ![]() ![]() |
Same here, just why i fitted paddleshift to my SC... Makes it much better to drive and i must be saving at least 30% of gear changes... Craig ![]() |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
Mine has now done 64K, I bought it 18 months ago with 43K on the clock. So far so good. I drive it very steady and I have never towerd and was told the car was never used to tow by previous owner. Taking these factors into account I am hoping my gearbox goes on and on. That said I am thinking of doing a geabox oil change in the next few months. Still undecided. FFRR TD6 HSE
