Home > Technical (L322) > red oil / fluid leaking |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Hi folks,
3rd May 2012 4:16pm |
Power steering possibly? |
3rd May 2012 4:17pm |
The steering fluid appears to be a shade of yellow. I am wondering if it could be the gearbox oil, so might check that tommorrow to see if the level is down MY2010 TDV8 Vogue Ipanema Sand
3rd May 2012 4:21pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Gearbox oil is a honey colour when new then black with age. Could be coolant as its that far back. Take your cap of the reservoir with the engine running (not hot) and look at the telltail jet. Should be either green/blue or red/orange. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
3rd May 2012 4:24pm |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 |
red could be transmission fluid try running the car whilst in park and check cooler lines running from the passenger side of the gearbox running up to the side of the engine if it is the cooler pipes they maybe only leaking under pressure, but if it tastes sweet it could be antifreeze |
3rd May 2012 4:26pm |
ooops thought it was a TD6 for some reason so pipes may not be in the same place |
3rd May 2012 4:27pm |
just checked the coolant and it is red, but it seems too thin to be the be the oily red substance collecting on the afore mentioned subframe under the joing between gearbox and engine MY2010 TDV8 Vogue Ipanema Sand
3rd May 2012 4:36pm |
The front diff is up there |
3rd May 2012 4:40pm |
the front diff appears to be ok... no sign of leaks. Ill get under it again tommorrow for a good look. i looked at the power steering fuid under the bonnet and it looks more like green that red, so i do not think that it is the cause of the leak.
3rd May 2012 5:55pm |
When your under there take your camera as well. I had a coolant leak from the top of the engine at the back and it was running down round the bell housing looking like something from the gearbox. As the coolant was hot it had become quite sticky as the residue lost the fluid that makes it up and was more concentrated. Have you felt what the fluid/oil is like to the touch? Does it leave a stain on your drive etc? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
3rd May 2012 9:17pm |
torque converter seal ?? you should be able to check this by looking inside the bell housing via the rubber cap in the bell housing |
3rd May 2012 10:08pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 962 |
If you have red fluid coming out of a 5HP24 then someone's put Dexron in it, which means you've got much bigger problems than just a leak.....
4th May 2012 3:27pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
What color is your coolant?
4th May 2012 10:30pm |
Hi folks , just to update,
14th May 2012 6:15am |
