![]() | Home > Maintenance & Mods (L322) > Preview to coming IIDTool update... |
Not on my IIDTool ![]() sorry - couldn't resist. It's coming guys. It's not going to do anyone much good if we have to release 10 versions. Christian and Patrick are doing all they can to try to get this out to everyone asap. Just a bit more patience with us please.
Hi Jon, No, the update has not yet been released and yes, it will def turn off the TPMS. Just FYI: the IIDTools on the shelf at dealers have an earlier FW version. So you will likely have to update the FW even if you wait till the release is out before purchasing. But doing the update only involves logging in to the GAP website, downloading an EXE file, plugging the IIDTool into your PC via USB, and running th file. Even with a slow internet connection it shouldn't take more than 1-2 mins. I will post here as soon as there is info on the release of the update. Regards, Steve ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3894 ![]() ![]() ![]() |
Oh Happiest of Days |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
Perfect, thanks for the quick responses, i won't have to have the TPMS fixed now i will just turn it off for good!
patiently waits for his beta login access to tell him there's a release....
Ah, finally that stupid single point entry is *off* and I have my DRL's and FMH lights all sorted. Happy chap. Land Rover Addict
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 192 ![]() ![]() ![]() |
Just got my IID Tool and sent off my activation request .... looking forward to playing later hopefully.
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 ![]() ![]() ![]() |
V 2.17 |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
I have been a tester for the last few weeks using the latest software update.
Had to laugh....my RR came from a dealership, owned by them. Nav on the go was ON - and I've been using the hack cos I never thought it was off!?!?! Land Rover Addict
As a quick explanation for some of the betas who may not yet have V 2.17: we decided to split the betas into 'phases' to keep from having to respond to the same problems numerous times. These problems usually arise because we do not have all LR/RR models with all options available to test on in-house. We chose the betas who were most responsive with their feedback and also based on the vehicle types/options we needed to test on.
Just used v2.17 ... fantastic .... managed to:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
interested in the lowering bit, does the setting go right across the board ie, access, standard,high and motorway mode.. ... - .- -.
Thanks, Stephen! Stan, The early L322 (02-05) can be lowered or raised as you want: either all (access, standard, etc) or at each height setting individually (access, standard, etc). In addition, you can change the vehicles attitude, as in standard height you have the options front, rear, or both together. The later L322 (06>) can only be raised or lowered 'en block' - that is all height settings together. We hope to implement a separate adjustment option for these vehicles later. ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
All this teasing us with version 2.17, how cruel you guys can be.
