Home > Maintenance & Mods (L322) > Preview to coming IIDTool update...
Page 8 of 8 <12345678
ahebron
New Zealand
I would just like to say thank you to SteveMFr and his colleagues. This morning I had a look at the IID Gap Tool website and saw that 2.17 is available so have downloaded and had a play.
1 question though. I see I can adjust settings for the FBH but I have a basic spec HSE without the centre screen and I have removed the factory stereo. How can I drive the FBH or is it an automatic thing that the car decides.
Thanks
Adrian VW Amarok 2014 Highline auto
Post #128697 1st Jul 2012 12:12am
you probably havnt got a FBH adrian..
have you a link to the IIDTool software download? ... - .- -.
Post #128715 1st Jul 2012 10:56am
ahebron
New Zealand
Oh yes I do, I've seen it beneath the battery:D
And from what I have read all TD6 have them
And as we are in the middle of winter it would be rather nice to be able to preheat the cabin.
Post #128719 1st Jul 2012 11:11am
so it comes on automatically when below a certain temperature but no timed option. ... - .- -.
Post #128721 1st Jul 2012 11:14am
SteveMFr
Site Sponsor
Hi Adrian,
Once the park heat function has been activated, there are 2 potential methods of running the park heater:
- programming a timed start through the Satnav Monitor or the MID radio (unproven AFAIK but should work as it does in BMWs with the same radio). If you've removed the MID radio (how do you set the clock?) you will not be able to program a timer. I have seen pics of aftermarket radio installs with the MID mounted in the glovebox to retain these functions (if your pixels were dead a BMW MID from ebay will work as well).
- remote control activation. This was avail as an option and, depending on the year of the RR, either had the Webast T60 or T90 remote. I don't remember if the 03's had the earlier version - there is a section in the wiki above with info on this IIRC. Otherwise info can be found in threads using the search function. The difference in the RR wiring between the remotes is actually only the shape of the plug for the remote receiver - both will work. The receiver plug has 3 wires - gn/wht, R/?, and Bn. For the FBH to switch on, 12v need to be switched to the gn/wht wire. You can do this with a toggle switch, timer, etc - but be careful not to run the FBH too long or the batt will be dead.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #128841 2nd Jul 2012 7:58am
ahebron
New Zealand
Ah.
Thats a neat idea putting the MID in the glove box, I have extra space since I removed the CD changer. At present when I need to adjust the clock I plug it into the cable that I recessed below the dash top speaker. The MID display is unfortunately missing a few lines so I will look for a BMW unit.
Thanks guys
Post #128850 2nd Jul 2012 8:55am
millerj90
I must be having a bit of a "thick" day here because I cant find the link on the GAP site to download the new (2.17) software.
Any pointers?
Many Thanks
Post #129371 4th Jul 2012 1:35pm
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
http://www.gap-diagnostic.com/ l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #129372 4th Jul 2012 1:38pm
SteveMFr
Site Sponsor
You'll need to register and log in. The login is at the top of all pages.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #129402 4th Jul 2012 3:59pm
millerj90
Got it now thanks.
For some reason i din't have the "My Gap" tab at the top of the screen. Logged out, then loggeg in again, and hey presto.
Awesome tool !!!!!!!
Post #129404 4th Jul 2012 4:02pm
Flashman
I am having the same issue, I have unlocked the unit, tested it on the car, then log in to the site but there is no MyGap button.
I have tried Explorer on my PC but does not make any difference. Still missing after reboot..
Just re-read the activation email and it says it will send another email about the update! So I guess it has to be manually updated their end. Tom
Current Drive
Previous Drives
Post #130950 13th Jul 2012 6:26pm
flashman, clear your cookies and try again ...my gap is definitely there ... ... - .- -.
Post #130956 13th Jul 2012 7:08pm
Flashman
All good now. When you buy it and activate it they have to update their customer database to allow you access to the MyGap part of their site. Email arrived this morning and all updated.
The customer service at GAP has been great, they promptly answered my questions despite me not reading the first email properly.
Great tool, already enjoying changing all the settings and clearing the 19 faults. Tom
Current Drive
Previous Drives
Post #131038 14th Jul 2012 12:03pm
