Home > General > fan noise behide centre clock |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6406 |
I believe it is the fan that checks the internal temperature on the car (There is the small vent in the dash in that area). Once the systems have shut down (red light goes off by gearstick) it should turn off, if not before, unless it doesn't! .
30th Apr 2012 5:18pm |
dannyp15 Member Since: 21 Sep 2011 Location: essex Posts: 244 |
thats the 1
30th Apr 2012 5:24pm |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Had a BMW that did the same... I thought it was a fault, but no, it is supposed to do that. I clean the dust out of the vent every now and again. Could yours be blocked? Could you leave a window open, lock up car, and check if you can hear it 15 or so minutes later? Previously..
30th Apr 2012 6:49pm |
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 |
Had the same thing on my 2004 TD6, was sure it never shut off, but read the book and it takes 16 minutes after shut down befor it shuts off. and sure enough stop watch in hand spot on 16 minutes it shuts off
1st May 2012 12:55am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35166 |
it does stop eventually.... ... - .- -.
1st May 2012 7:44am |
mine is always on it has never turned off ive never been in the car when it wasnt off
1st May 2012 9:15am |
when you unlock the car it switches on..
1st May 2012 9:21am |
1st May 2012 9:22am |
as you sit, its down by your right knee.....this flap hides the obd port which sometimes gets left open causing a drain...not saying it is the solution but you have to start somewhere.. ... - .- -.
1st May 2012 9:39am |
thanks Stan |
1st May 2012 9:43am |
so what i will do is sit in the car tonight for 16 mins to see if it goes off also i will clean the little vent just in case that is blocked |
1st May 2012 10:07am |
you'll probably find you have to lock the range to get the ecu's to all power down...with you inside you will set of the alarm... ... - .- -.
1st May 2012 10:15am |
what if i sit still lol
1st May 2012 10:16am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16232 |
Long time to sit stationary!
1st May 2012 10:27am |
