Home > General > fan noise behide centre clock
dannyp15
United Kingdom 2004 Range Rover Autobiography 4.4 V8 Alaska White
when i turn my car off or get in it later there is a buzzing/fan noise coming from behind the centre console
any ideas as i think this is what keep flattening my battery
someone said it might be the climate control fan
Big Cry
Post #119690 30th Apr 2012 4:08pm
I believe it is the fan that checks the internal temperature on the car (There is the small vent in the dash in that area). Once the systems have shut down (red light goes off by gearstick) it should turn off, if not before, unless it doesn't! .
Post #119692 30th Apr 2012 4:18pm
dannyp15
thats the 1
it is always on never goes off even when the car powers down Twisted Evil
Post #119694 30th Apr 2012 4:24pm
Had a BMW that did the same... I thought it was a fault, but no, it is supposed to do that. I clean the dust out of the vent every now and again. Could yours be blocked? Could you leave a window open, lock up car, and check if you can hear it 15 or so minutes later? Previously..
Post #119703 30th Apr 2012 5:49pm
Ziggy
Australia
Had the same thing on my 2004 TD6, was sure it never shut off, but read the book and it takes 16 minutes after shut down befor it shuts off. and sure enough stop watch in hand spot on 16 minutes it shuts off
Zigg "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #119733 30th Apr 2012 11:55pm
it does stop eventually.... Thumbs Up ... - .- -.
Post #119739 1st May 2012 6:44am
dannyp15
mine is always on it has never turned off ive never been in the car when it wasnt off
i leave the car all night soon as i get in the car its on and ive also getting a battery drain from somewhere
and im sure its this
i bought a solar 12v panel from maplins last night to see if that will help
Post #119747 1st May 2012 8:15am
when you unlock the car it switches on..
check your obd port flap isnt open, this sometimes causes a drain.... ... - .- -.
Post #119749 1st May 2012 8:21am
dannyp15
obd port flap ???
Post #119751 1st May 2012 8:22am
as you sit, its down by your right knee.....this flap hides the obd port which sometimes gets left open causing a drain...not saying it is the solution but you have to start somewhere.. ... - .- -.
Post #119753 1st May 2012 8:39am
dannyp15
thanks Stan
Post #119756 1st May 2012 8:43am
dannyp15
so what i will do is sit in the car tonight for 16 mins Whistle to see if it goes off also i will clean the little vent just in case that is blocked
Post #119758 1st May 2012 9:07am
you'll probably find you have to lock the range to get the ecu's to all power down...with you inside you will set of the alarm... ... - .- -.
Post #119760 1st May 2012 9:15am
dannyp15
what if i sit still lol
how would you suggest to do this stan
many thanks
Post #119762 1st May 2012 9:16am
Long time to sit stationary!
Craig Laughing
Post #119766 1st May 2012 9:27am
