Home > Technical (L322) > Increasing the range of the key fob remote |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
this works......
24th Apr 2012 6:32am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
It really does, done it myself several times. No idea how though!?!? |
24th Apr 2012 9:15am |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 |
Best way to get brain tumor |
24th Apr 2012 1:02pm |
5IMON Member Since: 27 Nov 2011 Location: London Posts: 165 |
I haven't even looked at the link but I know what it is
24th Apr 2012 1:07pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I assume there is no issue with the receiver ariel (it piggy backs on the heated rear window wires which are also used by the RDS radio if I remember correctly ). Mine has a ridiculous range - easily 300ft with a clear view of the car. Is the keyfob charging OK , have you tried your other key? Steve
24th Apr 2012 4:27pm |
How can i test if the key is charging ? I take it , it charges whilst in the ignition? |
26th Apr 2012 7:22pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8531 |
Car should post a message on the dash. There is nothing that can't be fixed with a hammer๐๐
26th Apr 2012 9:44pm |
It should post a message if the key isn't charging you say? |
26th Apr 2012 9:56pm |
And now the key fob doesn't work, Help |
27th Apr 2012 9:11pm |
WAZZY786 Member Since: 26 Nov 2011 Location: NEWCASTLE Posts: 26 |
I have the same problem with my 2006 - right pain. But I would suspect it's something to do with the car rather than the fob - I only had one fob, so got another one made by LR and it's the same (will only work if you're up close to the car). Mind you the Top Gear way does work, but still only while you're near the car - sometimes place the key on my hand - not my head! - and that works.....managed to dodge the funny stares lol
29th Apr 2012 11:46am |
Tamman Member Since: 30 Jul 2019 Location: Delhi Posts: 2 |
My 2003, HsE 4.4 v8 has same problem.. key only works about 2 meters max.. replaced the RF reciever at the back without any luck.. pl advice what to do... ๐ค |
26th Dec 2019 6:03pm |
