Home > Technical (L322) > Increasing the range of the key fob remote
5IMON
Its strange you know, on my L322 , I could walk to the end of my driveway and be able to unlock and lock the car. Now with my 07tdv8 I have to stand within 6 feet of the car otherwise I won't be able to unlock or lock it.
The key fob I'm using is only 7 months old too.
Any ideas?
Post #118831 23rd Apr 2012 11:52pm
this works......
Mr. Green ... - .- -.
Post #118836 24th Apr 2012 7:32am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
It really does, done it myself several times. No idea how though!?!? Very Happy
Post #118844 24th Apr 2012 10:15am
CSK
France 2013 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Best way to get brain tumor
Post #118857 24th Apr 2012 2:02pm
5IMON
I haven't even looked at the link but I know what it is Very Happy
Anyone else have sit range problem with their key fob
Post #118859 24th Apr 2012 2:07pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
I assume there is no issue with the receiver ariel (it piggy backs on the heated rear window wires which are also used by the RDS radio if I remember correctly ). Mine has a ridiculous range - easily 300ft with a clear view of the car. Is the keyfob charging OK , have you tried your other key? Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #118878 24th Apr 2012 5:27pm
5IMON
How can i test if the key is charging ? I take it , it charges whilst in the ignition?
Post #119238 26th Apr 2012 8:22pm
Car should post a message on the dash. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #119257 26th Apr 2012 10:44pm
5IMON
It should post a message if the key isn't charging you say?
Post #119258 26th Apr 2012 10:56pm
5IMON
And now the key fob doesn't work, Big Cry Help
Post #119397 27th Apr 2012 10:11pm
WAZZY786
United Kingdom 2006 Range Rover Vogue TDV8 Stornoway Grey
I have the same problem with my 2006 - right pain. But I would suspect it's something to do with the car rather than the fob - I only had one fob, so got another one made by LR and it's the same (will only work if you're up close to the car). Mind you the Top Gear way does work, but still only while you're near the car - sometimes place the key on my hand - not my head! - and that works.....managed to dodge the funny stares lol
IF you do find a fix please let me know - it is annoying!!
Post #119548 29th Apr 2012 12:46pm
Tamman
India 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
My 2003, HsE 4.4 v8 has same problem.. key only works about 2 meters max.. replaced the RF reciever at the back without any luck.. pl advice what to do... ๐Ÿค”
Post #538561 26th Dec 2019 7:03pm
