Home > Technical (L322) > Wheel alignment done.....still problems
the_engineer
United Kingdom 2004 Range Rover Autobiography Td6 Buckingham Blue
So further to my post in January...
I got back in the country this week and put the rangey straight into the dealer to have the full alignment done. Four hours later and 300 pounds lighter he comes and says you still have a lot of fault lights up. OH REALLY, why do you think it was brought to you in the first place. Bearing in mind I had explained everything to him, including the active fault lights and active alarms in the code reader and the work that had been done on the track rod end to have kicked all these alarms off. Cant say I was impressed. As I had other appointments I couldn't hang around for them to start extracting more coins from my pocket with their diagnostic machine
Anyway... The steering wheel now sits straight as it should and the car rides in a straight line, however the HDC, Air suspension etc etc still all come into alarm. The code reader is showing steering angle plausibility and yaw plausibility faults. I have tried the lock to lock steering and had the batt disconnected for a short spell. I am running out of ideas and I am quite frustrated.
Anyone got any ideas of what I could try next. Has anyone used the blackbox reader and came across these plausibility faults?
Post #116312 4th Apr 2012 10:26am
You need the 4 wheels aligned, sounds like they have only aligned the front wheels which because the back axle is now out it throws the steering angle sensor out by more than 12 degrees and throws a fault
Post #116318 4th Apr 2012 10:40am
the_engineer
thats what was done initially hence why it was in at land rover yesterday for 4 hours on the 3d alignment machine getting all four wheels corrected
Post #116324 4th Apr 2012 11:15am
I would hazard a guess that whoever did it hadn't a clue what he was doing and the geometry will be well out hence the warnings popping up on the dash.
You need to take it back to them and tell them to align it properly
Post #116350 4th Apr 2012 1:55pm
the_engineer
like i said before, it was mucked up first time round by a local garage. Yesterday is was in the Range Rover service centre having the geometry re-aligned on the 3d laser alignment machine. I have the report of the before and after measurements. They are now within Range Rover tolerances. The alarms were all up before I took it to range rover, hence why i just handed them 300 quid
Post #116361 4th Apr 2012 2:20pm
You might need your steering angle sensors recalibrating to suit your new geometry. You sensors might have been Censored up by the Indy who started the problem. Not a big job and would push LR to do that seeing as you have just spewed £300 in their direction. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #116401 4th Apr 2012 5:09pm
It's not a £300 job to do a 4 wheel alignment, it should be around £60 maximum
I have mine done at Pro Grip in Larbert as I had changed the rear bushes and the dash was flashing all sorts of lights and warnings after my local McConechys tyres depot made a hash of the alignment.
Post #116420 4th Apr 2012 7:33pm
+1 had mine done a few weeks back £80 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #116427 4th Apr 2012 7:56pm
Landrover Mad
2003 Range Rover Vogue Td6 Buckingham Blue
I would personally erase any historicial fault codes from the air suspension ecu, steering angle sensor and ABS ecu, if a fault code resides in any one of these three systems the symptoms you have mentioned will be generated.
All the best,
Stephen
Post #118769 23rd Apr 2012 4:35pm
wedgel322
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Mine also had the rear bushes done a couple of months ago and the 4 wheel alignment was £60. That was at an indy. 2003 Range Rover HSE 3.0 TD6
Java Black, Cream Leather Heated seats all round, Sat Nav, Rear TV's.
2013 Range Rover Autobiography 4.4 SDV8
Black, black and piano black. Rear entertainment system. 22 inch turbines
Post #118807 23rd Apr 2012 9:20pm
