Home > In Car Electronics (L322) > Headlamp Wiring Advice Needed? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Need to hack into the headlamp wiring to set up my fogs as DRLs. There are warnings everywhere about the 25000 volts on the bi-xenons so want to make sure I get this right!
16th Apr 2012 5:51pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35264 |
i wish i took notice of my set up tim.....stick a multimeter in the headlamp plug and do the usual like turning on the ignition and read the readings .. ... - .- -.
16th Apr 2012 7:37pm |
i'll have a look at mine tomorrow... ... - .- -.
16th Apr 2012 7:46pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Slight hi-jack - Can you retrofit bi-xenons? My TDV8 has standard halogens Land Rover Addict
16th Apr 2012 8:17pm |
But what about the 25000 volts . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
16th Apr 2012 8:21pm |
The description of the wiring and feeds for halogen and bi-xenon appears to be the same, but i don't know enough about it to say yeah or nay. Suggest start a new thread for this? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
16th Apr 2012 8:23pm |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 |
Really? My tdv8 has xenons and I thought they all did Are you talking about the separate high beams? If so, I believe it is normal for these to be halogen still - something to do with the fact that xenon doesn't come on instantaneously, important for flashing the lights - the main beam shifts it's pattern to be full beam slightly later |
16th Apr 2012 10:12pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16280 |
In all L322's from 02-08 you can get both Xenon and Halogen headlamps depending on spec... Only the 09my> that comes with Xenon headlamps across the range...
16th Apr 2012 10:31pm |
Thank you for enlightening me, Craig - to work!! . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
16th Apr 2012 11:19pm |
tim,
17th Apr 2012 7:10am |
ok, had a look but its all taped up pretty well but what i can see is that the ignition is green/brown and the headlight on feed is yellow/green.....hope this helps.. ... - .- -.
17th Apr 2012 9:21am |
LH side (Passenger side RHD)
17th Apr 2012 5:21pm |
Is there an "easy" way to put the headlight unit back in. Seems you have to fiddle and struggle for 15 minutes, then suddenly it slots into place .
17th Apr 2012 6:01pm |
15 minutes is the easy way tim... ... - .- -.
17th Apr 2012 7:54pm |
