Home > In Car Electronics (L322) > Headlamp Wiring Advice Needed?
Need to hack into the headlamp wiring to set up my fogs as DRLs. There are warnings everywhere about the 25000 volts on the bi-xenons so want to make sure I get this right!
I need to pick up an ignition feed (to turn on the DRLs) and a "switched on" feed (to turn the DRLs off when the headlights come on)
RH Headlamp Wiring
LH Headlamp Wiring
Reading the Electrical Library pdf it says that an ignition feed is fed to both headlamps by a RED/GREEN wire. This tallies as there is a RED/GREEN wire going to both. (see pictures)
The Electrical Library then says the "switched on" feed is through a YELLOW/BLUE for the RH side and WHITE/GREEN for the left. These are thicker than the RED/GREEN wires. (see pictures)
Can anyone confirm I am on the right lines, before I blow myself or the car up Wink .
Post #117797 16th Apr 2012 5:51pm
i wish i took notice of my set up tim.....stick a multimeter in the headlamp plug and do the usual like turning on the ignition and read the readings .. ... - .- -.
Post #117807 16th Apr 2012 7:37pm
i'll have a look at mine tomorrow... Thumbs Up ... - .- -.
Post #117814 16th Apr 2012 7:46pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Slight hi-jack - Can you retrofit bi-xenons? My TDV8 has standard halogens Rolling Eyes Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #117820 16th Apr 2012 8:17pm
But what about the 25000 volts Twisted Evil .
Post #117821 16th Apr 2012 8:21pm
The description of the wiring and feeds for halogen and bi-xenon appears to be the same, but i don't know enough about it to say yeah or nay. Suggest start a new thread for this? Wink .
Post #117822 16th Apr 2012 8:23pm
Joe, the high voltage is within your headlamp pal... The feeds to the plugs are all standard 12v, the ECU's and High voltage box is hidden inside the rear of your headlamp...
And yes the wiring colours you mentioned are the ones you want...
Craig Thumbs Up
Post #117840 16th Apr 2012 9:47pm
simon1233
Really?
My tdv8 has xenons and I thought they all did Question
Are you talking about the separate high beams? If so, I believe it is normal for these to be halogen still - something to do with the fact that xenon doesn't come on instantaneously, important for flashing the lights - the main beam shifts it's pattern to be full beam slightly later
Post #117842 16th Apr 2012 10:12pm
In all L322's from 02-08 you can get both Xenon and Halogen headlamps depending on spec... Only the 09my> that comes with Xenon headlamps across the range...
Craig Thumbs Up
Post #117844 16th Apr 2012 10:31pm
Craig Thumbs Up
Thank you for enlightening me, Craig - to work!! Thumbs Up .
Post #117846 16th Apr 2012 11:19pm
tim,
the high voltage only occurs from the ballast to the hid bulb, the ballast is fed by 12 volts which ends at the end of the plug .... ... - .- -.
Post #117851 17th Apr 2012 7:10am
ok, had a look but its all taped up pretty well but what i can see is that the ignition is green/brown and the headlight on feed is yellow/green.....hope this helps.. ... - .- -.
Post #117872 17th Apr 2012 9:21am
LH side (Passenger side RHD)
YELLOW/GREEN stripe is the dipped beam
WHITE/GREEN stripe is the full beam
Thanks for your guidance Smile .
Post #117999 17th Apr 2012 5:21pm
Is there an "easy" way to put the headlight unit back in. Seems you have to fiddle and struggle for 15 minutes, then suddenly it slots into place Evil or Very Mad .
Post #118007 17th Apr 2012 6:01pm
15 minutes is the easy way tim... Laughing ... - .- -.
Post #118025 17th Apr 2012 7:54pm
