Home > General > Newbie - Roll!
Lapchien
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Newbie - Roll!
So after months of looking I now have a 58 plate TDV8 Vogue in Stornoway Grey, my first ever RR! Very nice car!
My last car was an Audi A3 3.2, which felt like driving along the floor, compared to the RR. My only issue as such is that it's a bit hairy driving around corners or bends, anything much over 30 / 40 feels like it'll topple over! Will that feeling go away with confidence, and can it be pulled around the bends without too many problems?
Post #116372 4th Apr 2012 2:30pm
That feeling won't leave you as long as you wing it round bends at speed , centre of gravity dictates how soon you'll be on your side driving in that style … not so much 30 / 40 .. thats just a taster , wait till you wing it round at 70 / 80 .. now thats Butt clenching stuff ... Laughing Laughing ====================================
Post #116375 4th Apr 2012 2:43pm
supershuttle
Get the IIDTool and lower the suspension a bit, enables cornering at breakneck speeds then Shocked Geoff
Post #116392 4th Apr 2012 3:30pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
+1 That's what I did ...... 15mm lower all round Twisted Evil Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #116398 4th Apr 2012 3:55pm
Lapchien
Had it a week now, got in this afternoon to see a leak at the top of the drivers side A pillar, dripping and sodden headlining! Have emailed the dealership, no reply as of yet. Any ideas what that might be? Seal at the top of the screen?
Post #116405 4th Apr 2012 4:40pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
My earlier L322 had a leak in very nearly the same place - wet headlining, occasional drip landing on speedo binacle etc.
The mastic seal around the windscreen was at fault (probably replacement windscreen fitted badly during previous ownership maybe?) Anyhow... the problem took months to get sorted back and forth from dealership because they couldn't locate exact leak - even when spraying hose on problem area???
Turns out the leak would only occur if the vehicle was parked downward facing on a slight hill - even then (with water being hosed) it took at least ten minutes before any drips started to form.
They claimed they fixed the fault by removing and refitting the screen - but I think they just squirted some more sealant in the problem area Whistle ... they did replace the heading though which was handy 'cause it was pretty mucky Wink
Hope they sort yours out asap
Post #116419 4th Apr 2012 6:28pm
Lapchien
There's a chip in the windscreen so they have said they will replace the screen, they said that they will do this leak at the same time.
Post #116428 4th Apr 2012 6:58pm
that sounds like a pretty good result. Thumbs Up There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #116436 4th Apr 2012 8:40pm
mrd1990
United Kingdom 2002 Range Rover HSE Td6 Oslo Blue
As for feeling like the car will topple over on corners..
It's impossible. If you go in to a corner too fast, you'll just slide on the leather seats. If you're going stupidly fast, you will get some under steer like a hatchback... but it will never fall over.
4000 miles of welsh B road driving has taught me this Thumbs Up
Post #116475 5th Apr 2012 9:14am
Let's hope they are not some famous last words Mr. Green .
Post #116481 5th Apr 2012 10:11am
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Quote:
It's impossible.
No it isn't. It's possible to roll anything if you go in fast enough. To be fair, you would have to drive like a total @rse to get a FFRR to go over though.
If you want to hustle one through the twisties quickly, try a two stage turn in. Basically, gently ease into the turn to allow the car to settle, then haul on the rest. Quite astonishing for a big old truck. 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #116504 5th Apr 2012 12:22pm
Lapchien
Getting more used to it now, as above I go a bit slower into the corners, but once in the corner itself I found that you can really power out of the bend.
Went on the motorway today, how effortless was that!
Really lookimng forward to a trip down to Italy this summer Very Happy
Post #116569 5th Apr 2012 6:36pm
mrd1990
"Let's hope they are not some famous last words"
Post #116598 5th Apr 2012 9:54pm
SteveMFr
Site Sponsor
Laughing
Exactly. I guarantee a L322 will roll over given the right circumstances.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #116609 5th Apr 2012 10:40pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Laughing Especially given the width, take a corner too fast+run wide>touch of understeer+clip opposite kerb=shiny side down.
Post #116633 6th Apr 2012 9:31am
