Home > Technical (L322) > Sat Nav Froze on logo and Flashing knob!
44ark
2006 Range Rover Vogue SE Supercharged Zermatt Silver
Hi guys
The wife managed to run the car out of fuel the other day and then ran the battery flat while trying to start it after refilling the fuel.
The car had to be jump started due to the flat battery.
Ever since then the Sat nav, audio, etc is just stuck on the Land Rover logo with a flashing orange light.
I have disconnected the battery a couple of times and also left it over night but this still has not fixed the issue any other ideas?
The car is a 2006 SC Vogue SE with touch screen nav so the most system
starting to pull my hair out now!! Supercharged LPG!!
Post #114024 20th Mar 2012 1:04pm
Can you "see" the car with Bluetooth on your phone?? Previously..
Post #114037 20th Mar 2012 2:13pm
i think you need a new battery... ... - .- -.
Post #114042 20th Mar 2012 2:28pm
44ark
no no systems fire up Supercharged LPG!!
Post #114049 20th Mar 2012 2:50pm
44ark
battery was new about 10 months ago and seems to be holding its charge ok now Supercharged LPG!!
Post #114050 20th Mar 2012 2:51pm
44ark
any other ideas guys at full lose on this one Supercharged LPG!!
Post #115581 30th Mar 2012 10:06am
Worth checking/linking out the BT module... I had water damage in mine, same faults as yours. Check the large connector for signs of corrosion.. When you unplug the fibre connector can you see a red light at one side?
I take it you have checked all the fuses connected with all those units?? There are fuses front and rear.. Sorry if obvious, all worth checking. Previously..
Post #115604 30th Mar 2012 12:15pm
Lolo
Ireland 2011 Range Rover HSE TDV8 Santorini Black
Wives seem to get a lot of blame on this forum.. I betchya most of the time it's blatant lies Rolling Eyes Laughing
Post #115608 30th Mar 2012 12:31pm
still reckon you need a new battery....... ... - .- -.
Post #115609 30th Mar 2012 12:32pm
44ark
where are the fuses at the rear i have unplugged everything at the rear and plugged back in and also pulled all the fuses in the glove box will check the bluetooth module tonight but have tried with out the bluetooth plugged in and still no joy Supercharged LPG!!
Post #115932 2nd Apr 2012 7:59am
It won't work by just unplugging the Bluetooth. Did you check for a red light on one of the fibres? Can you follow it from module to module? And you have scanned with a mobile phone to see if the cars Bluetooth is visible? Read my post about the problem I had. http://www.fullfatrr.com/forum/post99656.html#99656
It might help.. Previously..
Post #115940 2nd Apr 2012 9:13am
44ark
yeah the bluetooth is not visible from a phone and there was light coming out the fibre cable but didnt take any notice to see if it was one or both lights will check tonight when i get home thanks
There is no water ingress as checked this but will try the straw trick with the bluetooth module tonight. Supercharged LPG!!
Post #115945 2nd Apr 2012 9:24am
Lolo
More fuses at boot right hand side
Post #115950 2nd Apr 2012 10:01am
44ark
ok thanks will have a dig around tonight Supercharged LPG!!
Post #115951 2nd Apr 2012 10:04am
44ark
contraband thanks mate saved a lot of time it was indeed the Bluetooth module.
I have temp removed the Fibre connectors and pulled them out the clip and taped them together now everything is working as it should apart from the bluetooth.
There is no water ingress so am guessing i have a blown bluetooth module.
Thanks for all the help on this thought it was going to get very expensive.... Supercharged LPG!!
Post #116195 3rd Apr 2012 1:33pm
