Home > Technical (L322) > Sat Nav Froze on logo and Flashing knob! |
44ark Member Since: 01 Apr 2011 Location: faringdon oxon Posts: 58 |
Hi guys
20th Mar 2012 1:04pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 |
i think you need a new battery... ... - .- -.
20th Mar 2012 2:28pm |
no no systems fire up Supercharged LPG!! |
20th Mar 2012 2:50pm |
battery was new about 10 months ago and seems to be holding its charge ok now Supercharged LPG!! |
20th Mar 2012 2:51pm |
any other ideas guys at full lose on this one Supercharged LPG!! |
30th Mar 2012 10:06am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
Worth checking/linking out the BT module... I had water damage in mine, same faults as yours. Check the large connector for signs of corrosion.. When you unplug the fibre connector can you see a red light at one side?
30th Mar 2012 12:15pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
Wives seem to get a lot of blame on this forum.. I betchya most of the time it's blatant lies |
30th Mar 2012 12:31pm |
still reckon you need a new battery....... ... - .- -.
30th Mar 2012 12:32pm |
where are the fuses at the rear i have unplugged everything at the rear and plugged back in and also pulled all the fuses in the glove box will check the bluetooth module tonight but have tried with out the bluetooth plugged in and still no joy Supercharged LPG!! |
2nd Apr 2012 7:59am |
It won't work by just unplugging the Bluetooth. Did you check for a red light on one of the fibres? Can you follow it from module to module? And you have scanned with a mobile phone to see if the cars Bluetooth is visible? Read my post about the problem I had. http://www.fullfatrr.com/forum/post99656.html#99656
2nd Apr 2012 9:13am |
yeah the bluetooth is not visible from a phone and there was light coming out the fibre cable but didnt take any notice to see if it was one or both lights will check tonight when i get home thanks
2nd Apr 2012 9:24am |
More fuses at boot right hand side |
2nd Apr 2012 10:01am |
ok thanks will have a dig around tonight Supercharged LPG!! |
2nd Apr 2012 10:04am |
contraband thanks mate saved a lot of time it was indeed the Bluetooth module.
3rd Apr 2012 1:33pm |
