![]() | Home > Technical (L322) > Sat Nav Froze on logo and Flashing knob! |
44ark Member Since: 01 Apr 2011 Location: faringdon oxon Posts: 58 ![]() ![]() |
Hi guys
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35326 ![]() ![]() |
i think you need a new battery... ... - .- -.
no no systems fire up Supercharged LPG!! |
battery was new about 10 months ago and seems to be holding its charge ok now Supercharged LPG!! |
any other ideas guys at full lose on this one Supercharged LPG!! |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
Worth checking/linking out the BT module... I had water damage in mine, same faults as yours. Check the large connector for signs of corrosion.. When you unplug the fibre connector can you see a red light at one side?
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Wives seem to get a lot of blame on this forum.. I betchya most of the time it's blatant lies |
still reckon you need a new battery....... ... - .- -.
where are the fuses at the rear i have unplugged everything at the rear and plugged back in and also pulled all the fuses in the glove box will check the bluetooth module tonight but have tried with out the bluetooth plugged in and still no joy Supercharged LPG!! |
It won't work by just unplugging the Bluetooth. Did you check for a red light on one of the fibres? Can you follow it from module to module? And you have scanned with a mobile phone to see if the cars Bluetooth is visible? Read my post about the problem I had. http://www.fullfatrr.com/forum/post99656.html#99656
yeah the bluetooth is not visible from a phone and there was light coming out the fibre cable but didnt take any notice to see if it was one or both lights will check tonight when i get home thanks
More fuses at boot right hand side |
ok thanks will have a dig around tonight Supercharged LPG!! |
contraband thanks mate saved a lot of time it was indeed the Bluetooth module.
