Home > Technical (L322) > Fuel gauge
Glm
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Fuel gauge
Hi all, the gauge on my vogue after filling up keeps going from full to empty with low fuel warning light on and stays like that for a while then back to full and then back empty ? Any ideas ? Cheers Current tdv8 range vogue 07
Post #115520 29th Mar 2012 9:31pm
Try a a battery disconnect procedure? .
Post #115537 30th Mar 2012 2:00am
Glm
Is there a link on this ? Cheers Current tdv8 range vogue 07
Post #115548 30th Mar 2012 7:00am
My write up
http://bimma.me.uk/2010/03/12/disconnectin...ation-rhd/ .
Post #115584 30th Mar 2012 10:45am
Glm
Thanks for this I will have a go ! Just not sure about the positive disconnect after looking at it ? Current tdv8 range vogue 07
Post #115668 30th Mar 2012 5:47pm
You should only really need to disconnect the earth connection, but give it 10 - 20 minutes once off to allow all the systems to completely shut down, before reconnecting. Try to put the clamp back on in one swift movement to avoid connect / disconnect /connect etc. .
Post #115670 30th Mar 2012 5:58pm
Glm
After reconnecting the terminal I still have reset the steering turning full lock left to right ? Current tdv8 range vogue 07
Post #115697 31st Mar 2012 6:24am
any battery dis-connection needs this, takes seconds to do... ... - .- -.
Post #115698 31st Mar 2012 7:17am
Glm
Thanks stan and I will be ok just doing the neg terminal ? Current tdv8 range vogue 07
Post #115700 31st Mar 2012 7:26am
as tim [joe90] says above re the neg terminal but again only a few seconds to take the positive terminal off....it'll be good practice for when you have to replace the battery.. Laughing ... - .- -.
Post #115701 31st Mar 2012 7:35am
The correct procedure is to switch the vehicle off and wait 20 minutes, then disconnect the negative lead, then disconnect the positive lead, then using a jump lead (piece of wire that has two crocodile clips) join the positive and negative leads together and leave them for 15 minutes. After 15 minutes remove the jump lead (crocodile clips) and reconnect the positive lead to the battery terminal and tighten up, then reconnect the negative lead to the battery and tighten up. Start up the engine and turn the steering full lock left, hold for 3 seconds then full lock right, hold for 3 seconds, then full lock left again and hold for 3 seconds. Job done
Jump lead with crocodile clips.....
Must not be connected to any terminals that are still connected to a battery
Post #115706 31st Mar 2012 8:12am
thanks john, procedure edited and put in the wiki.... Thumbs Up ... - .- -.
Post #115724 31st Mar 2012 11:08am
Glm
Thanks to everyone job done and gauge is now working correct ! Current tdv8 range vogue 07
Post #115727 31st Mar 2012 11:53am
