Home > Maintenance & Mods (L322) > Viscous fan failure
Page 2 of 4 <1234>
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Until I was confident that engine would not overheat, I carried viscous fan in boot, just in case, now hub lives in garage.
(I did a 200 mile around trip with five adults plus luggage as well, still ran ok Smile )
Post #113548 17th Mar 2012 2:13pm
I might give this a try and at least tomorrow can work as a test day for it...
Iirc the electric fan was just to cool the ac comdensor when required butay be wrong.
This removal and replacement was always touted as being an mpg improver as its always wasting power where as electric only works when needed... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113554 17th Mar 2012 2:52pm
Strangely mine is now working again!!
Still think i'll remove it though, if it helps mpg and stops the engine working so hard as well Smile
Thanks everyone for the advice Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113700 18th Mar 2012 4:39pm
Richcl
These paragraphs are taken from RAVE, the second one explains that the electric fan can cool down engine if it gets to hot.
Post #113702 18th Mar 2012 4:46pm
Cheers RichL Smile gives me extra confidence in the system working Smile
I wonder if the viscous unit is for offload use as well, ie low speed and incase the rad gets caked in mud maybe??? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113707 18th Mar 2012 5:43pm
ahebron
New Zealand
Ah, it sounds like the TD6 is a lot like the 300TDi.
The 300TDi happily runs without its viscous fan.
These diesel Land Rovers are thermally efficient which I suppose is why LR fitted the FBH to all TD6.
RichL did yours sound like a Boeing 737 on take off, mine sounds like this at low speed till the engine passes approx. 2000rpm after that the noise disappears. Most noticeable from cold.
No sneaking away in my TD6.
Adrian
Post #113719 18th Mar 2012 7:23pm
Mine was doing that Adrian until it self healed!! possibly due to the threat of removal Very Happy
Scarey at about 4k rpm though as even at motorway speeds other cars could still hear it Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #113720 18th Mar 2012 7:28pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
Cam-Tech-Craig wrote:
Richcl wrote:
I've removed mine, it's been off a month or so and did a 1000 mile two day trip to Edinburgh and back no problem.
(Not towing BTW)
Needle stays a rock steady middle of the gauge.
Ive often thought about removing mine as it drives me mad (noise) but im unsure weather the electric fan comes in when it gets very hot (like on a disco 2) anyone know?
Craig Thumbs Up
The SC doesn't have an additional electric fan.......it has quite an advanced viscous fan that is also controlled by the ECU, good description of operation on Topix Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #113744 18th Mar 2012 9:53pm
fisha
To be honest, if you're not reaching running temp, it's more likely that the thermostat is stuck open . I fannied about with radiator muffs and stuff like this discussion on an old 300tdi which still never made normal temp. Bothered to take the time to change the stat and it ran upto full temp even in the coldest weather. V8 or else ...
Post #113751 18th Mar 2012 10:19pm
Richcl
I changed both EGR and main thermostat on mine fisha, after having over cooling problems (Details on another thread) So when I put it all back togeather decided to see if it would run with no fan. Smile
Post #113753 18th Mar 2012 10:27pm
(Not towing BTW)
Craig Thumbs Up
Mine does have an electric fan... In front of the rad... Strange...
Craig Whistle
Post #113756 18th Mar 2012 11:23pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
Is it easy to remove the Viscous fan, or do you need to remove the radiator etc? Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #116157 3rd Apr 2012 9:03am
ahebron
New Zealand
Release the scrivets holding the fan shroud to the radiator, 2 at the top and 1 at the bottom. Lift the shroud up 3/4 inch to clear the holding brackets and slide the shroud back towards the engine as far as you can. With 2 fan spanners release the l/h thread fan viscous nut and spin the fan off.
Simple as that. Laughing
Adrian VW Amarok 2014 Highline auto
Post #116163 3rd Apr 2012 9:40am
Richcl
No viscous fan, 21c last week, and still half way up the temp gauge.
Engine sounds quieter (as in large fan drawing in air) and meatier (as in you hear 6 cyl grumble) and maybe even an improvement in MPG Smile
Post #116172 3rd Apr 2012 10:08am
Flashman
Nice one Ahebron, I will try it out. Tom
Current Drive
Previous Drives
Post #116206 3rd Apr 2012 3:26pm
Page 2 of 4 <1234>
