Home > Maintenance & Mods (L322) > Viscous fan failure |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
Until I was confident that engine would not overheat, I carried viscous fan in boot, just in case, now hub lives in garage.
17th Mar 2012 2:13pm |
I might give this a try and at least tomorrow can work as a test day for it...
17th Mar 2012 2:52pm |
Strangely mine is now working again!!
18th Mar 2012 4:39pm |
These paragraphs are taken from RAVE, the second one explains that the electric fan can cool down engine if it gets to hot.
18th Mar 2012 4:46pm |
Cheers RichL gives me extra confidence in the system working
18th Mar 2012 5:43pm |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 |
Ah, it sounds like the TD6 is a lot like the 300TDi.
18th Mar 2012 7:23pm |
Mine was doing that Adrian until it self healed!! possibly due to the threat of removal
18th Mar 2012 7:28pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
To be honest, if you're not reaching running temp, it's more likely that the thermostat is stuck open . I fannied about with radiator muffs and stuff like this discussion on an old 300tdi which still never made normal temp. Bothered to take the time to change the stat and it ran upto full temp even in the coldest weather. V8 or else ... |
18th Mar 2012 10:19pm |
I changed both EGR and main thermostat on mine fisha, after having over cooling problems (Details on another thread) So when I put it all back togeather decided to see if it would run with no fan. |
18th Mar 2012 10:27pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Mine does have an electric fan... In front of the rad... Strange... Craig |
18th Mar 2012 11:23pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
Is it easy to remove the Viscous fan, or do you need to remove the radiator etc? Tom
3rd Apr 2012 9:03am |
Release the scrivets holding the fan shroud to the radiator, 2 at the top and 1 at the bottom. Lift the shroud up 3/4 inch to clear the holding brackets and slide the shroud back towards the engine as far as you can. With 2 fan spanners release the l/h thread fan viscous nut and spin the fan off.
3rd Apr 2012 9:40am |
No viscous fan, 21c last week, and still half way up the temp gauge.
3rd Apr 2012 10:08am |
Nice one Ahebron, I will try it out. Tom
3rd Apr 2012 3:26pm |
