Home > Technical (L322) > TDV8 Tickover
Binks
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
TDV8 Tickover
Could someone please tell me what the tickover of my 3.6 TDV8 should be? It seems to be too fast at 800 rpm or at least sounds too fast or is that typical for this engine? My petrol V8 4.4 was quieter and seemed slower. If you select neutral then it is quieter which is normal I know as the petrol was the same.
Also how long should it take the dealer to programme the remotes for the park heater (latest versions) ? TDV8 3.6 2010 Santorini Black / Jet Interior
Series 3 1983 petrol swb hard top Marine Blue/Cream Cab - perfect!
Evoke 2013 (wife's) Santorini black, black leather, huge wheels, all the bits.....lucky girl!
Post #112707 12th Mar 2012 10:48pm
fisha
Diesels often idle faster during warm up rather than running richer a you get in a petrol.
Does it do this once warm? V8 or else ...
Post #112709 12th Mar 2012 10:56pm
Binks
Is 800 too fast then? It does it all the time to be honest.... TDV8 3.6 2010 Santorini Black / Jet Interior
Post #112712 12th Mar 2012 11:15pm
sleepezy
Thinks that's about the same as mine. Will check on the morning!
Post #112715 12th Mar 2012 11:43pm
my td6 is about 750 'ish if that helps.. ... - .- -.
Post #112728 13th Mar 2012 8:20am
fisha
at a very general level most engines have an idle speed between 700 and 800rpm, with diesels sometimes having their idles kept a little bit higher than petrols in order to keep the engine idling smoothly. If you lower the idle of a diesel too low, then it can lead to more engine shake ... which for an RR is not really what your looking for.
Remember your engine is an 8 cylinder engine. So compared to your average 4 cylinder diesel car engine which sound like a tractor at idle, for every rpm, there is double the amount of cylinders tapping and banging in your V8.
It will sound twice as fast ... cause there is double the amount ... but it'll be running at the same rpm. Does that make sense? V8 or else ...
Post #112754 13th Mar 2012 10:16am
mzplcg
Here you go then. Thumbs Up
Post #112845 13th Mar 2012 4:50pm
T24RES
+1 as mzplcg Thumbs Up
Post #112847 13th Mar 2012 4:53pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
+2 Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #112848 13th Mar 2012 4:54pm
Googsy
+3 Present :2008 TDV8 HSE
Gone Audi A5 2.7TDI
Gone Discovery 3 HSE
Gone Mercedes CLK
Gone Range Rover 2.5 DSE
Post #112856 13th Mar 2012 5:11pm
