![]() | Home > Technical (L322) > TDV8 Tickover |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1459 ![]() ![]() |
Diesels often idle faster during warm up rather than running richer a you get in a petrol.
Binks Member Since: 03 Mar 2012 Location: Bristol Posts: 17 ![]() ![]() ![]() |
Is 800 too fast then? It does it all the time to be honest.... TDV8 3.6 2010 Santorini Black / Jet Interior
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Thinks that's about the same as mine. Will check on the morning! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35633 ![]() ![]() |
my td6 is about 750 'ish if that helps.. ... - .- -.
at a very general level most engines have an idle speed between 700 and 800rpm, with diesels sometimes having their idles kept a little bit higher than petrols in order to keep the engine idling smoothly. If you lower the idle of a diesel too low, then it can lead to more engine shake ... which for an RR is not really what your looking for.
Here you go then.
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
+1 as mzplcg |
+2 Land Rover Addict
+3 Present :2008 TDV8 HSE
