Home > eBay & Bargain Spots > A good day at Aldi this Sunday
Been after an air compressor and tools for a while, will dip my toe now
http://www.aldi.co.uk/uk/html/offers/offer...z_src=main Discovery 4 HSE
Post #112178 9th Mar 2012 9:39pm
that 10m air hose will do me.. Thumbs Up
good find adam , thanks.
Post #112179 9th Mar 2012 9:45pm
Spot blaster could be handy Thumbs Up
Post #112180 9th Mar 2012 9:52pm
Typical, no cash I'll after the sale lol FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #112181 9th Mar 2012 9:54pm
The woven jute effect mats look like they could be possibly blue with ivory edging. Whistle
Post #112182 9th Mar 2012 9:57pm
I've been fancying some air tools too - so I checked Machine Mart as a comparisson - their cheapest compressor is actually slightly cheaper - but with a lower displacement - in fact they don't do one as high as 9.5CFM Shocked
Their sub £100 model is half the weight of the Aldi one - I can't decide if that makes it better or worse Confused
Machine Mart Compressors
The air hose reel looks cheap as does the impact wrench - they are both £20 cheaper ! The Accessories kit is close to MM in price but MM have a curly air cable (better)
Post #112199 10th Mar 2012 7:53am
In compressor land bigger is better, you just never know when you'll need that extra CFM, I know through experience as I have 3 different compressors here Big Cry
Noise is the next thing you need to take into account, modern compressors have fast running high speed motors, possibly 2800-3200rpm and they make a lot of noise, remember to switch it off when finished or the neighbours will be complaining. The quietest compressors are the older cast iron slow running machines, they run at between 750 and 1400 rpm and are very quiet (see below)
Anyone buying the Aldi equipment don't forget to buy the filter regulator as compressors produce a lot of water and you don't want it going into the airtools
This is my 3 phase beast, it puts out 23CFM and is powerful enough to be able to keep up without the aid of an airtank.
This 3 phase compressor is an Ingersoll Rand from 1968. It is so quiet I can run it at midnight and my neighbours won't hear it
The only problem is it is a little slow to build up pressure as it doesn't produce enough CFM for me
Here's a video clip of the first time I ran it up to pressure
Air tools are next, these can range from a few pounds to a good few hundred.
Don't expect a £20 Aldi air wrench to remove rusted nuts & bolts that are seized on, it wasn't designed for that, but it will have its uses and for your £20 you will have great fun loosening your nuts Shocked
Remember to oil the tools before and after use each day, the moisture from the compressor can kill these tools very quickly
Post #112201 10th Mar 2012 8:23am
Air tools
This is my selection
Nut busting Ingersoll Rand 2135QTiMAX (780 ft/lbs maximum torque) Thumbs Up
Paint drier which I use for drying the cars after washing. (Consumes 20CFM)
Air Sander
Air cut-off tool
Air drill
Top two are air de-scalers, then Air hacksaw & 3/8 drive air ratchet, bottom row are another two 1/2" wrenches
Don't forget blow guns, one of the most useful items. Large and small sprayer guns & sealant applicator
My latest purchase was an Ingersol Rand air chisel which I had to source from America
Perfect for pushing the driveshafts out of the hubs on the FFRR
A word of caution...
When using an air wrench do not be tempted to use ordinary sockets as they will shatter sending particles everywhere. Use only impact sockets, they're not expensive and because they are 6 sided are less prone to slipping
Post #112211 10th Mar 2012 9:11am
Some great top tips there, thanks Thumbs Up Discovery 4 HSE
Post #112214 10th Mar 2012 9:44am
RR8701
United Kingdom 2005 Range Rover Vogue 4.4 V8 Java Black
[quote="47p2"]Air tools
[IMG:800:600]http://i219.photobucket.com/albums/cc110/ourclassiccars/1a.jpg[/img]
[IMG:800:600]http://i219.photobucket.com/albums/cc110/ourclassiccars/2a.jpg[/img]
Air Sander
[IMG:800:600]http://i219.photobucket.com/albums/cc110/ourclassiccars/3a.jpg[/img]
Air cut-off tool
[IMG:800:600]http://i219.photobucket.com/albums/cc110/ourclassiccars/4a.jpg[/img]
Air drill
[IMG:800:600]http://i219.photobucket.com/albums/cc110/ourclassiccars/5a.jpg[/img]
[IMG:799:599]http://i219.photobucket.com/albums/cc110/ourclassiccars/6a.jpg[/img]
[IMG:799:599]http://i219.photobucket.com/albums/cc110/ourclassiccars/7a.jpg[/img]
[img:640:480]http://img.auctiva.com/imgdata/6/7/9/5/4/8/webimg/395526099_o.jpg[/img]
When using an air wrench do not be tempted to use ordinary sockets as they will shatter sending particles everywhere. Use only impact sockets, they're not expensive and because they are 6 sided are less prone to slipping[/quote]
LOLLL Rolling with laughter Rolling with laughter Rolling with laughter
LOOKS LIKE SOMETHING OUT THE SAW FILMS LOL
Post #112232 10th Mar 2012 11:01am
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Had An Aldi compressor for 3 years now, I would recomend it a a cheap starter tool, but the 50 litre tank does not last long if you are sparaying or using the impact wrench. The impact wrench is not that powerful, it will take your wheels off, but don't expect it to take a crank pully bolt out.
Pretty sure most of the tools dont come with the male fitting you need to plug them into the hose so make sure you know where to get them from 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #112315 10th Mar 2012 8:38pm
