![]() | Home > Technical (L322) > 2005 L322 can gateway failure? |
The can module itself, have you checked it over and maybe opened it up to check the circuitry inside?
Also maybe try an get the contact details for this guy and ask very nice if he could advise |
skippy Member Since: 09 Jan 2010 Location: Sheffield Posts: 41 ![]() ![]() ![]() |
Hi pal the gateway module is behind the touch screen it's a little white box about 2" by 1" I think from memory you have to take the top of the dash to get to it I am not really sure but i think it keeps all the ccf files in there for your car so you need to be able access it to reformat the new gateway with your car settings if it's that,hopefully it's just the most bus that has come loose also dont know if you have done this but try and post on blackbox's forum to get some better technical advice (ronnie and gabriella) are really helpful
Paul Grainger Member Since: 13 Jun 2010 Location: Mansfield Posts: 23 ![]() ![]() ![]() |
kingpleb where abouts are you? Swapping the module would be a good test. Skippy says it lives behind the touchscreen, I've had this out before but can't remember seeing another module in that position that has fibre connectors - but then again I wasn't looking for one at that time!
Sure the module is under the integrated head unit behind the touchscreen don't think the most fibre optic goes to it think it's just the can bus but don't quote me on that |
I may be wrong, but i think that I read on another post that the can gateway is also interfaced to the MOST bus, as the 'source'. I wish I knew more, but there just doesn't seem to be that much info on this unit. |
As above ask BBS first off but I'm just outside Thorne if you want to pop up anytime this week?
done a little more digging for you and found this
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
One thing to check before you start digging around the touchscreen - a tired battery gives slower and slower start up from the touchscreen - how old is yours (you start getting lots of symptoms before it is noticeably slower to crank) ? |
Battery is fine.
Found the infotainment relay - RHS rear fusebox - and it definitely isn't energised.
The relay is in the boot on the right hand side there is abit of of kit that helps diagnose most problems it's called a most prism sorry cant remember the part number it goes in place of the most ring and re loops the light so effectively bypassing the module the only thing is you have to go round every module though to find where the link is broken |
sorry you beat me to it |
Still no luck, if I put a bridge across the infotainment relay contacts then I get the land rover logo permanently on the touchscreen. All fuses are good. I think I will be dismantling the dashboard this weekend! Whilst I was driving to work today the radio burst into life for about thirty seconds before once again getting the black screen of death! |
