Home > Technical (L322) > 2005 L322 can gateway failure? |
The can module itself, have you checked it over and maybe opened it up to check the circuitry inside?
6th Mar 2012 7:33pm |
Also maybe try an get the contact details for this guy and ask very nice if he could advise
6th Mar 2012 7:38pm |
skippy Member Since: 09 Jan 2010 Location: Sheffield Posts: 41 |
Hi pal the gateway module is behind the touch screen it's a little white box about 2" by 1" I think from memory you have to take the top of the dash to get to it I am not really sure but i think it keeps all the ccf files in there for your car so you need to be able access it to reformat the new gateway with your car settings if it's that,hopefully it's just the most bus that has come loose also dont know if you have done this but try and post on blackbox's forum to get some better technical advice (ronnie and gabriella) are really helpful
6th Mar 2012 7:43pm |
Paul Grainger Member Since: 13 Jun 2010 Location: Mansfield Posts: 23 |
kingpleb where abouts are you? Swapping the module would be a good test. Skippy says it lives behind the touchscreen, I've had this out before but can't remember seeing another module in that position that has fibre connectors - but then again I wasn't looking for one at that time!
6th Mar 2012 8:00pm |
Sure the module is under the integrated head unit behind the touchscreen don't think the most fibre optic goes to it think it's just the can bus but don't quote me on that
6th Mar 2012 8:37pm |
I may be wrong, but i think that I read on another post that the can gateway is also interfaced to the MOST bus, as the 'source'. I wish I knew more, but there just doesn't seem to be that much info on this unit. |
6th Mar 2012 8:54pm |
As above ask BBS first off but I'm just outside Thorne if you want to pop up anytime this week?
6th Mar 2012 9:15pm |
done a little more digging for you and found this
6th Mar 2012 10:18pm |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
One thing to check before you start digging around the touchscreen - a tired battery gives slower and slower start up from the touchscreen - how old is yours (you start getting lots of symptoms before it is noticeably slower to crank) ? |
7th Mar 2012 8:35am |
Battery is fine.
7th Mar 2012 10:04am |
Found the infotainment relay - RHS rear fusebox - and it definitely isn't energised.
7th Mar 2012 9:42pm |
The relay is in the boot on the right hand side there is abit of of kit that helps diagnose most problems it's called a most prism sorry cant remember the part number it goes in place of the most ring and re loops the light so effectively bypassing the module the only thing is you have to go round every module though to find where the link is broken
7th Mar 2012 9:57pm |
sorry you beat me to it try and check fuse 8 in the passenger fuse box as well think some power comes through there also check your pm have sent you the 2005 my audio descriptions
7th Mar 2012 10:35pm |
Still no luck, if I put a bridge across the infotainment relay contacts then I get the land rover logo permanently on the touchscreen. All fuses are good. I think I will be dismantling the dashboard this weekend! Whilst I was driving to work today the radio burst into life for about thirty seconds before once again getting the black screen of death! |
8th Mar 2012 7:59pm |
