Home > LPG > Lpg converted! Where is your air compressor located now? |
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 |
On mine the air compressor is located in the right hand storage compartment using a Preston Air Bracket which is not too bad for noise.
6th Mar 2012 10:39pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Trist,
6th Mar 2012 11:22pm |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
I need to lpg mine and am dreading it, found a local authorised prins vsi dealer,
6th Mar 2012 11:28pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7808 |
I think a lot of the relocated compressor noise issues come from them not being on propper mounts, ie rubber feet and such like to iscolate vibration from the body.
7th Mar 2012 8:36am |
Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608 |
By its very nature when you remove the compressor from its factory supplied sound proof shell (they call it a turtle ) it will always be noisier The art is to mount it on rubber feet and deaden down the sound with as much sound proofing as possible. On my old car I used fire rated wall insulation and then put the sound proof lining from the turtle over the top (Back/Far Right) Worked a treat
7th Mar 2012 10:55am |
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 |
Andy wat size tank did u have mine looks monster in comparison |
7th Mar 2012 11:04am |
95 litre tank with a BRC Sequent System fitted almost 6 years when the car had done 28k miles and to the best of my knowledge still going strong with 115k + miles now
7th Mar 2012 11:08am |
It must just me being stupid then ive got a 95ltr BRC system to cracking bit of kit, my compressor was relocated to the storage pocket on the right and a bracket and foam coffin made round it |
7th Mar 2012 11:18am |
JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 232 |
My compressor sits in the same place as the one shown above, with no additional soundproofing. The only time I hear it is on start up and that's it.
7th Mar 2012 11:43am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35339 |
question..where do you chaps put the spare and have you had any problems with loading other stuff in the back for instance... ... - .- -.
7th Mar 2012 12:11pm |
The spare is in the garage lol but tyre weld in the boot like Andy
7th Mar 2012 12:17pm |
7th Mar 2012 2:08pm |
3 weeks to the lpg
7th Mar 2012 5:39pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
I'd say BRC, I've had two done with BRC, just make sure you get the twin Genuis max reducers, and the high capacity injectors.
7th Mar 2012 6:29pm |
