Home > LPG > Lpg converted! Where is your air compressor located now?
Page 1 of 4 1234>
Trist78
2004 Range Rover Vogue 4.4 V8 Java Black
Hi guys!
Had mine converted last week and found that i can now hear the compressor working!
Just wondering where your air compressor is now located? also what have you done to reduce the noise down.
I have done searches but couldnt find any that involve the above so apologies if there is.
Also just wondering also if you have found any difference before and after on the performance? Is it as smooth/powerful, and does it hold the gear longer?
Thanks in advance
Trist
Post #111354 6th Mar 2012 11:30pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
On mine the air compressor is located in the right hand storage compartment using a Preston Air Bracket which is not too bad for noise.
www.preston-air.com
I have a BRC lpg kit fitted and there is no difference on power or gearchange.
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #111356 6th Mar 2012 11:39pm
Trist,
Make sure the compressor has been mounted the correct way up as its life will be seriously reduced if not... Ever seen a workshop compressor led on its side!
No power liss with my LPG...
Craig Thumbs Up
Post #111367 7th Mar 2012 12:22am
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
I need to lpg mine and am dreading it, found a local authorised prins vsi dealer,
Looking to do it within the next 2 weeks, guess there's a lot of reading and research and
Let the company know how I want things
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #111368 7th Mar 2012 12:28am
mjdronfield
I think a lot of the relocated compressor noise issues come from them not being on propper mounts, ie rubber feet and such like to iscolate vibration from the body.
A mate of mine had a 4.4 LPG conversion, and that's what he took from the compressor noise issue......
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #111400 7th Mar 2012 9:36am
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
By its very nature when you remove the compressor from its factory supplied sound proof shell (they call it a turtle Shocked ) it will always be noisier Confused The art is to mount it on rubber feet and deaden down the sound with as much sound proofing as possible. On my old car I used fire rated wall insulation and then put the sound proof lining from the turtle over the top Wink (Back/Far Right) Worked a treat Thumbs Up
Some relocate the compressor in the rear off side storage compartment but thats not an option if the tow bar holder is installed as on mine Rolling Eyes
Andy.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #111450 7th Mar 2012 11:55am
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Andy wat size tank did u have mine looks monster in comparison
Post #111453 7th Mar 2012 12:04pm
Ajay(UK)
95 litre tank with a BRC Sequent System fitted almost 6 years when the car had done 28k miles and to the best of my knowledge still going strong with 115k + miles now Thumbs Up
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
Post #111454 7th Mar 2012 12:08pm
cliffy
It must just me being stupid then ive got a 95ltr BRC system to cracking bit of kit, my compressor was relocated to the storage pocket on the right and a bracket and foam coffin made round it
Post #111456 7th Mar 2012 12:18pm
JW911
My compressor sits in the same place as the one shown above, with no additional soundproofing. The only time I hear it is on start up and that's it.
I have a 95 litre tank (70-75 litres useable depending upon temperature) giving around 250 miles per fill. 45000 fault free miles so far. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #111461 7th Mar 2012 12:43pm
question..where do you chaps put the spare and have you had any problems with loading other stuff in the back for instance... ... - .- -.
Post #111465 7th Mar 2012 1:11pm
cliffy
The spare is in the garage lol but tyre weld in the boot like Andy
No issues with my gear on top of it
Post #111467 7th Mar 2012 1:17pm
JW911
What Cliffy says. The 95 litre tank in the wheel well is intended to allow the boot to remain standard. 2021 3.0 P400 Vogue
Post #111481 7th Mar 2012 3:08pm
salb
3 weeks to the lpg
prinz vsi system or brc
sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
Post #111530 7th Mar 2012 6:39pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
I'd say BRC, I've had two done with BRC, just make sure you get the twin Genuis max reducers, and the high capacity injectors.
Mine has the air compressor pump in the spare wheel well with the tank, it didn't quite fit, but after a little modification of the casing around the pump, it was persuaded to fit! No additional noise, no orientation issue with the pump.
Have you considered where to put the gauge? I got mine put under the dsc button. Look at my past posts for pictures! 2012 SDV8 Vogue SE
Post #111542 7th Mar 2012 7:29pm
Page 1 of 4 1234>
