Home > Technical (L322) > Tyre noise when turning?
Page 1 of 3 123>
Cappo
2006 Range Rover Vogue 4.4 V8 Java Black
I've noticed that the tyre/road noise increases on my car when I'm turning, more so to the right than to the left. First noticed it a while back, driving along my road where I live - you can only do about 20mph due to the cars parked and the width of the road but there's a 90 degree right-hander where, well, all I can say is that the tyre noise increases - noticeably. It's less so on a LH turn, and at higher speeds you don't notice it, probably because of all the other noise going on (wind etc).
At first I thought it must be the road surface on that particular bend but now I'm noticing it elsewhere.
Tyres are Michelin in the correct 255/50R20 size, can't remember the model name but they're M&S stamped and have done c. 6000 miles, still with loads of tread (5-6mm I'd say without measuring).
Any thoughts? All I can think of is wheel alignment, although the car steers and tracks true and the wheel is dead straight.
Post #110826 4th Mar 2012 5:53pm
tyre pressures ok, dont know if this would make a difference but you never know.... ... - .- -.
Post #110829 4th Mar 2012 6:06pm
Cappo
Did check them when I first noticed the noise Stan and car still does it!
Post #110831 4th Mar 2012 6:09pm
never noticed it myself really....the range does have a very good turning circle but at max i suppose it would strain the rubber a bit...is it more noticeable in standard or access ? ... - .- -.
Post #110835 4th Mar 2012 6:13pm
Cappo
It's in standard as the bit where I notice it most is still 2-300 yards from home, so it's standard, about 20mph and not full lock, just whatever it needs to do a tight-ish 90 degree turn, although it's still on the public highway at the time, so it's not TOO tight a bend, just residential.
Post #110841 4th Mar 2012 6:43pm
best do what my wife does when she hears any car noises, she turns up the volume on the radio.. Mr. Green ... - .- -.
Post #110876 4th Mar 2012 10:31pm
simon1233
I've noticed this on mine as well. As it is in with the dealer this week for another issue I thought I would ask them to check the bearings asi am suspecting a noisy cv joint (my noise does or get worse or better when applying the brakes which would normally correct a noisy wheel bearing at low speed) or some other differential type noise....
Post #110890 4th Mar 2012 11:49pm
Cappo
Keep us posted Simon. Mine does it whether there is power on or not.
I'm telling myself that it's nothing. Especially as I'm off to the Alps for a week next weekend......in the FFRR........ Shocked
AND the warranty runs out this month!!
Post #110907 5th Mar 2012 12:59am
Have your front hubs checked for wheel bearing play...
Craig Thumbs Up
Post #110908 5th Mar 2012 1:00am
Cappo
Standard top - bottom, side - side and diagonalplay checks Craig? Will go and do that in a minute and report back!
Post #110945 5th Mar 2012 9:38am
Cappo
Right, reporting back Smile
There's no bearing play at all in either front wheel. HOWEVER....there is some play in the rack. Detectable from both sides, you can move the wheel slightly from side to side accompanied by a slight knock as the play in the rack is taken up.
It's not the track rod ends, they're fine, and the track rod moves with the play in the wheel - therefore it's in the rack.
Question is, is this normal? I know on some cars designed to be used offroad, there is some play in the steering systems (although that's typically older LRs I guess, and of course they're steering boxes, not racks).
But I guess that could be the cause of the tyre noise, if the play is allowing the wheel(s) to chatter slightly when cornering?
Post #110947 5th Mar 2012 10:09am
i dont think its a mechanical problem cappo....if the tyre is making the noise then its the tyre thats at fault..
i would try the same manoeuvre at a different location , maybe a supermarket carpark and if it still does it then its the tyre , if it doesn't then its the road surface at home..
many years ago i had a old motor with unheard of tyres on it and they squealed like starsky and hutch when going round corners at 5 mph... ... - .- -.
Post #110948 5th Mar 2012 10:14am
Another quick check for you, if you run the palm of your hand over the tread of your tyres one at a time. First in a clockwise direction and then in an anticlockwise direction and see if your tyres are wearing in the shape of a saw blade... i.e. in one direction your hand slides easily and the other gets harder (as if stopping on saw blade teeth)
Ive seen this as a problem on quite a few RR's with Premium brand tyres lately... Causes all manner of strange noises like wheel bearing noises etc etc. The driver does not notice the problem until it gets really loud! usually because they drive it every day!
Craig Thumbs Up
Post #111132 6th Mar 2012 9:30am
may i offer the technical term for this anomaly = 'feathering'..... Mr. Green ... - .- -.
Post #111135 6th Mar 2012 9:36am
Ahh... I call it Censored ing Stan... Rolling with laughter Rolling with laughter Rolling with laughter
Craig Thumbs Up
Post #111140 6th Mar 2012 9:48am
Page 1 of 3 123>
