![]() | Home > Technical (L322) > Tyre noise when turning? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35611 ![]() ![]() |
tyre pressures ok, dont know if this would make a difference but you never know.... ... - .- -.
Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537 ![]() ![]() |
Did check them when I first noticed the noise Stan and car still does it! |
never noticed it myself really....the range does have a very good turning circle but at max i suppose it would strain the rubber a bit...is it more noticeable in standard or access ? ... - .- -.
It's in standard as the bit where I notice it most is still 2-300 yards from home, so it's standard, about 20mph and not full lock, just whatever it needs to do a tight-ish 90 degree turn, although it's still on the public highway at the time, so it's not TOO tight a bend, just residential. |
best do what my wife does when she hears any car noises, she turns up the volume on the radio.. |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
I've noticed this on mine as well. As it is in with the dealer this week for another issue I thought I would ask them to check the bearings asi am suspecting a noisy cv joint (my noise does or get worse or better when applying the brakes which would normally correct a noisy wheel bearing at low speed) or some other differential type noise.... |
Keep us posted Simon. Mine does it whether there is power on or not.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Have your front hubs checked for wheel bearing play...
Standard top - bottom, side - side and diagonalplay checks Craig? Will go and do that in a minute and report back! |
Right, reporting back |
i dont think its a mechanical problem cappo....if the tyre is making the noise then its the tyre thats at fault..
Another quick check for you, if you run the palm of your hand over the tread of your tyres one at a time. First in a clockwise direction and then in an anticlockwise direction and see if your tyres are wearing in the shape of a saw blade... i.e. in one direction your hand slides easily and the other gets harder (as if stopping on saw blade teeth)
may i offer the technical term for this anomaly = 'feathering'..... |
Ahh... I call it |
