Home > In Car Electronics (L322) > Voice control on ULF Bluetooth
mjdronfield
I have a 6th generation ULF but I don't have voice control , which I understand is part of it.
Does anyone know how to enable it ?
Thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #105797 6th Feb 2012 10:59pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
You need an ibus interface and a registered copy of Navcoder (the earlier free versions dont allow access the phone module Crying or Very sad ) which will then allow you to enable voice recognition. Or access to someone who has both Rolling Eyes
OR you need to source and connect the separate voice module but if your loom had the separate voice module connector already in it your current setup wouldn't function correctly Shocked
OR update your ULF to one "mit SES" (with voice) Thumbs Up
First option would be favourite Exclamation
Andy. 2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
SWMBO: 22MY Defender 110 HSE X Dynamic, Gondwana Stone.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Gone: 2003 Epsom Green 4.4i Vogue, LPG, Mk4 Nav, BMW Bluetooth Phone, Hybrid Tv Tuner,
Post #105946 7th Feb 2012 4:49pm
mjdronfield
Will this work ?
http://www.ebay.co.uk/itm/BMW-Diagnostic-S...4ab347c723
Thanks 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #105974 7th Feb 2012 6:27pm
mjdronfield
Hi,
I have RSW All Comms - will that lead work with Navcoder, does anyone know ?
Don't want to buy another lead if I don't have to.
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #108594 22nd Feb 2012 12:49pm
SteveMFr
Site Sponsor
No
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #108711 22nd Feb 2012 11:15pm
daveo
just a silly question, you have held the button on the steering wheel down until it bleeps and then speak your command.
you need an ibus interface to use navcoder V8 facelift Range Rover Autobiography 22" wheels.
Post #108719 23rd Feb 2012 12:38am
mjdronfield
Thanks Gents.
I've held the button down and nothing happens - other than it ringing the last person I called, if the phone is connected.
I've ordered an ibus interface cable, to go with the generic OBDII cable and the RSW All Comms cable, so I think I have a full set now !!
Will see how I get on.
Maybe I don't have it, but understand that voice was available after the 5th gen ULF.
I can't get at it to see if it says "Mit Ses", so we will have to see.
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #108770 23rd Feb 2012 11:01am
Ajay(UK)
Mark,
Did you car have the original factory phone kit in it? Either way one thing to check is to see if there is a spare blue 16pin plug at the end of a loom very close to the Nav computer. On the original phone kit the voice module was separate and bolted under the nav computer.
Even if the ULF has voice built in (which it should for Gen 6) if you have this loom the circuit wont complete without a "jumper plug"
Here's a picture from of my old 2003 FFRR:
This maybe the problem? The BMW SES Jumper Plug part number is clearly visible but you wont need it if your loom doesn't have the plug. That will probably depend on whether you car had a phone loom with a 54pin black plug or you connected a bluetooth adaptor loom directly into the white 12pin x400 plug on the cars main ICE loom?
Andy.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Post #108776 23rd Feb 2012 11:23am
mjdronfield
Hi Andy,
Thanks for your help.
My car didn't have a phone in it.
I rewired the 54 pin plug, and used that, as my car was pre-wired for phone at the factory.
I was aware of the SES jumper plug, but read various things on the net about it's not needed as the ULF has it built in. maybe thats not true.
I haven't seen a plug, but then I've not looked for one, if you see what I mean.
The rest of the system seems to work OK without a plug (if one isn't there).
I should have the Navcoder lead in a couple of days, and should then see if its enabled on the ULF.
I'll check to see if I have the blue connector near the Nav unit.
Cheers
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #108780 23rd Feb 2012 11:43am
Ajay(UK)
If you car was pre-wired at the factory then its quite possibe that you have the blue 16pin plug.
The quick and easy way to tell willl be can you speak "hands free" using the bluetooth or more importantly can the other person hear you Question If they can then you mic is working fine and your loom cannot have the voice module loom as all the SES jumper plug does is connect the "in and out" manly for the mic so no jumper = mic not working Exclamation
Assuming you kit is working fine in every other way then you can probably ignore all that I have said and revert to enabling voice using Navcoder Embarassed
Post #108784 23rd Feb 2012 11:56am
mjdronfield
My microphone is working fine, hands free - both ways.
The SES jumper is the only bit of it that I've had nothing to do with. Not sure if I've got it, if I need it, when its fitted, and whether you only have it if your car had a TCU............who knows ?
According to RAVE, for my car, the Voice Control Unit was, as you say, a seperate unit, located under the nav. As my car had no phone, and was prewired for phone only, I assume the voice bit isn't there.
Maybe then you can make the conclusion and "jump", that as voice is built into the newer ULF, the older voice part of the loom is not required.
All ideas and thoughts are valid at this stage.
I shall report back with my findings.
thanks again
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #108788 23rd Feb 2012 12:13pm
mjdronfield
I've enabled Voice Recognition with Navcoder, and its all working fine.
I now have someone else in the car, who doesn't understand me !!
Laughing 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #109627 27th Feb 2012 1:01pm
p38arover
Australia
Does this mean that, when I fit the ULF mit SES, the old Voice Recognition Module must be left in place? Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451237 18th Sep 2017 5:18am
mjdronfield
No, unplug it. I never had one, but others had issues leaving it in as there would be two on the ibus 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #451239 18th Sep 2017 6:47am
p38arover
Australia
Ok, will do. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #451248 18th Sep 2017 8:41am
