![]() | Home > Technical (L322) > BMW M62 engine in L322? |
bergxu Member Since: 18 Jan 2012 Location: Cincinnati Posts: 61 ![]() ![]() ![]() |
No, the engine was heavily modified for use in the FFRR. There were major differences in the design of the sump among other things...
I think you could get away with it if you used the donor as a tall block and implanted everything from the current engine like manifolds and loom and sump and sensors you may get away with it but it's unknown waters on here!!
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7865 ![]() ![]() ![]() |
If you are going to the trouble, I'd be dropping in a V8 from an M5........
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 ![]() |
As above, I very much doubt if any BMW engine will work. It may be the same basic engine, but it's very much modified, and you'd have a hell of a job getting the ancillaries to work, let along the ecu's. Range Rover-less at the moment - Pining! |
jsrr Member Since: 13 Feb 2012 Location: Sweden Posts: 6 ![]() ![]() ![]() |
My engine has a surface damage in one of the cylinders.
Does the block not have a part number ?
Hi.
