Home > Maintenance & Mods (L322) > Retro fitting Paddle Shift to early L322
Page 11 of 14 <123 ... 1011 121314>
stonosam
Australia
Apologies for not getting back to you. I have been away traveling and only got back today. I will book the car in this week and I will let you know how I get on. Here is to hoping. Cool
Post #97094 11th Dec 2011 11:42am
stonosam
Australia
Just to let you know. Could not convince my OD to download new transmission software:twisted: Only way forward would be a pre 2010 solution.
Post #99228 24th Dec 2011 5:21am
stonosam
Australia
Hi All,
I had just about given up trying to get my paddles to work when I read on another forum about a good small independent Land Rover service specialist.
I contacted him and gave him the background on my car as well as the information Baben had kindly provided me on his car. They agreed that it was very possibly a software issue and told me to bring the car in so that they could run some tests.
The bottom line is that I took the car in and they downloaded the latest transmission software and guess what it f'ing worked. I am stoked. Very Happy
I can't thank Baben enough for his support, encouragement and information on his car without which I would have simply given up. Bow down Also to Colin at BBS. Thumbs Up
Post #101120 11th Jan 2012 10:11am
x7mpp
FINALLY!!!!!! Hard wired my paddles after obtaining a BMW coupler with all three plug sockets that have pins. Wired in the link to the gear shift and they work! No delay and as factory, very pleased.
Post #101127 11th Jan 2012 10:49am
x7mpp
Just quickly. Im looking to upgrade to leather door cards and either a leather or alcantara headlining, can anyone point me to the right forum or pass on any advice?
Thanks in advance.
Post #101129 11th Jan 2012 10:51am
verydisco
carlos50 wrote:
Has anyone on here done this to the facelift 2007 MY yet then?. If the steering wheel has the paddles fitted already, a 2010 MY wheel, does this overcome the slip ring issue?.
Hi there.
Any good news regarding such Rangies please?
Post #107040 13th Feb 2012 2:47am
daveo
x7mmp, the slip ring you bought is it not a standard vogue one with heated steering wheel function
thanks dave0 V8 facelift Range Rover Autobiography 22" wheels.
Post #107145 13th Feb 2012 6:22pm
L4FLIROP
United States 2003 Range Rover HSE 4.4 V8 Adriatic Blue
Getting the feed from Steering wheel to Center Console
Matt, I think I have a solution to getting additional contacts to allow connection for the Paddle shifter.
If the Spiral Harness or clock spring is removed and uncoiled and an additional / identical length spring or cable is then bonded to the original one. This would add the additional contact that would be required. I am about to buy a used clock spring to test this out
[/img]
Post #109349 25th Feb 2012 5:12pm
salb
United Kingdom 2007 Range Rover Vogue SE Supercharged Santorini Black
Ok received my heated/paddleshift steering wheel from dan,
Now to sift through all of this lot, though I have read it numerous times,
Going to have to work it out, do like the hard wired route but still not sure if
This can be done on a 57 s/c
Sal RANGE ROVER OVERFINCHED 4.2 S/C
FRONT BUMPER O/F
REAR BUMPER. O/F
BOOT SPOILER O/F
22" ALLOYS. O/F
STAINLESS STEEL EXHAUST O/F
CARBON FIBRE WING MIRRORS & A PILLARS & CENTRE CONSOLE
Post #117452 13th Apr 2012 1:11pm
Ajay(UK)
United Kingdom 2015 Range Rover Autobiography SDV8 Indus Silver
Paddles arrived this week (thanks Dan) and are now fitted to my car. I found a suitable "temporary" 4pin female to female cable to use for now but its a bit long Embarassed
I have ordered one of these to use instead:
As per Baben's very useful information it's wired correctly as the + & - are illuminated Cool so that just leaves enabling the CCF Confused
The car is in for a service next week and I have spoken to the dealer and have arranged to have a word with the relevant technician about enabling paddle shift Shocked Lets hope it can be done or else I'm looking for a southerner with a faultamate Whistle
Andy. 22MY Defender 110 D250 HSE X Dynamic, Gondwana Stone.
SWMBO: 2022 RRS D300 Autobiography, Firenze Red.
Gone:2015 L405 SDV8 Autobiography, Indus Silver with Black Pack.
Gone: 2014 Discovery 4 HSE Luxury Firenze Red
Gone: 2006MY Java Black TD6 Autobiography
Gone: 2013 Jaguar XKR Convertible, Italian Racing Red with Ivory Seats
Gone: 2010MY Stornoway Grey TDV8 Vogue SE with RSE
Gone: 2008 Disco 3 HSE, Hybrid Tv + Retro-fit RSE System & DVD
Post #118445 20th Apr 2012 2:48pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Well i have assembled my SC conversion kit, remote setup, with the addition of powered LED's on the paddles working with only the one 12V supply for them and the RF unit in the steering wheel area.
this is a required mod as the transmitter has a common positive rail and not Negitive, otherwise the LED's simply fry the boards on the paddles due to a direct short on pulling the paddle with the black required to be an earth for the normal LED power up.
I therefore modify the boards like this and added independant earths for the LED's, using a battery i proved the whole system prior to fitting to the car.
you can see where I have removed the earth track and cleaned the side of the LED for a direct earth wire connection.
this allows the positive red to still be used and only requires the one adition wire in the steering wheel wiring per side.
will post some images of the fitting tomorrow and the 6 speed gearbox connections which should be the same as my previous posting....
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #125407 8th Jun 2012 6:42pm
robbo770
well got it all fitted today and it is great to have the paddles in a SC!!!
here is the centre consule power connections in a SC 2006 touchscreen facelift model
Green and White for positive ignition on and Brown for earth.
and for all you 2006 to 2009 owners the critical info for connecting to the gearbox for the shift up and down,
the Yellow on the Purple plug is the downshift and the Brown next to it in the middle is the upshift connections.
I again used the RF remote control mod and it worked again faultlessly.
I hope this helps everyone,
all in with one day to make both steering wheel loom and car consule loom, and then about 1 day to fit both parts.
Gone
Freelander 06 SE
Post #125501 9th Jun 2012 6:22pm
daveo
hi robbo770
you wrote:
Well i have assembled my SC conversion kit, remote setup, with the addition of powered LED's on the paddles working with only the one 12V supply for them and the LED's in the steering wheel area.
not sure what you have done there,please give me a bit more info..
thanks dave V8 facelift Range Rover Autobiography 22" wheels.
Post #125583 10th Jun 2012 2:59pm
robbo770
Hi Dave,
I have used the Maplin remote 2 channel unit method again on my 4.2 SC 2006 6 speed gearbox FFRR.
due to the RF transmitter having a positive 12v common on the PCB and with me running both the RF power supply and the LED's on the same feed,
I did not get LED's to work on my last installation due to the short when pressing the paddle which due to the black wire being the ground for the switch when pulling the paddle for the paddle PCB's and a positive feed going up the red wire I needed to seperate the common earth on the paddle PCB's due to the LED's needing to have a earth whilst allow the combination of either grey or blue to connect to the black to allow the paddles to replace the RF transmitter button switches with them being isolated from the LED's.
bar this it was a standard remote control installation again.
hope this helps Current vehicles
Gone
Freelander 06 SE
Post #125584 10th Jun 2012 3:06pm
robbo770
Here is a image of the wiring inside my steering wheel, marked up to help you all
cheers
Gone
Freelander 06 SE
Post #127928 27th Jun 2012 11:46am
