![]() | Home > Technical (L322) > HLDF Can bootloader problem |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35653 ![]() ![]() |
if yours is a touch screen then what you need is a 2009/2010 map disc which has an updated firmware included..ebay is your best bet. ... - .- -.
Maya Coyote Member Since: 14 Oct 2010 Location: Yekaterinburg Posts: 3 ![]() ![]() ![]() |
my VIN say it's 2005 model year (manufactured in 2004)
update:
the only thing i can think of is to disconnect the battery and wait 30 minutes ..hopefully this might reboot the sat nav and make it work properly..
bergxu Member Since: 18 Jan 2012 Location: Cincinnati Posts: 61 ![]() ![]() ![]() |
Land Rover TSB 86/02/05/NAS describes this exact problem (which I had on my '05) and the solution which is a software/firmware update. It takes 45 minutes and needs to be done by a stealer with a special boot disc which is LR p/n YIA500010 Cheers,
thanks for the info aaron.. |
No worries scarey, when my system went blank except for that message I was expecting a $2K+ bill for some component replacement. Thankfully, a little digging on LR Topix revealed the fix |
if anyone else has this problem then ask member wiggs nicely , he might be able to supply a link to download this firmware... ... - .- -.
what mav unit is it, mk4 or the denso, 2004/5 is right on the switch over, it uses ibus and canbus V8 facelift Range Rover Autobiography 22" wheels.
This is a pic of my NAV screen in my NAS '05 FFRR and the one which the firmware upload cured...
gliciouz Member Since: 09 May 2013 Location: Oslo Posts: 1 ![]() |
Just bought my `04 Vogue 2 weeks ago. Cd changer was acting a little weird and cds would not always play and magazine would get stuck some times while loading. Sorted after keeping the car off for a few mins then turning on but yesterday touch screen went blank with HLDF CAN BOOTLOADER message. I see people have success sorting this using update dvd.
i think that this 'HLDF CAN BOOTLOADER' firmware is available from a disco3 member on the disco3 forum.. ... - .- -.
