Home > Technical (L322) > HLDF Can bootloader problem
Maya Coyote
Russia 2005 Range Rover Vogue 4.4 V8 Zermatt Silver
Greetings.
Few months ago I get secondhand Land Rover Range Rover Vogue and have problem with sat/nav. Screen is blank with "HLDF can bootloader" message on it.
The dealer service in my town have checked all the connections and stuff, but could not solve the problem. The only thing that they have said - that it's corrupted firmware and they will try to ask manufacturer about firmware disk. But with time seems it's impossible for them to do.
Does anyone here have any friends dealers and can ask them about that firmware disk?
Post #31697 14th Oct 2010 10:07am
if yours is a touch screen then what you need is a 2009/2010 map disc which has an updated firmware included..ebay is your best bet. ... - .- -.
Post #31707 14th Oct 2010 11:51am
Maya Coyote
my VIN say it's 2005 model year (manufactured in 2004)
will solution with 2009/2010 map disc work in this case?
Post #31710 14th Oct 2010 12:29pm
Maya Coyote
update:
Today I borrowed a friend's DVD with map of Eastern Europe 2009/2010 (№ 464110-7570)
After inserting disc into the navigation system drive I can hear that the disc spins up, head leaves and returns once. But there are no sounds of reading from disc and message on screen do not change.
Any ideas?
Post #31903 15th Oct 2010 1:45pm
the only thing i can think of is to disconnect the battery and wait 30 minutes ..hopefully this might reboot the sat nav and make it work properly..
edit..this might help as well.. http://www.fullfatrr.com/forum/topic2294.html?highlight=hldf ... - .- -.
Post #31904 15th Oct 2010 1:54pm
bergxu
United States 2005 Range Rover HSE 4.4 V8 Zambezi Silver
Land Rover TSB 86/02/05/NAS describes this exact problem (which I had on my '05) and the solution which is a software/firmware update. It takes 45 minutes and needs to be done by a stealer with a special boot disc which is LR p/n YIA500010 Cheers,
Aaron
Post #107039 13th Feb 2012 2:08am
thanks for the info aaron.. Thumbs Up ... - .- -.
Post #107059 13th Feb 2012 10:21am
bergxu
No worries scarey, when my system went blank except for that message I was expecting a $2K+ bill for some component replacement. Thankfully, a little digging on LR Topix revealed the fix Wink
Seems that it only affected 2005 models of FFRR and LR3. Cheers,
Aaron
Post #107080 13th Feb 2012 12:29pm
if anyone else has this problem then ask member wiggs nicely , he might be able to supply a link to download this firmware... ... - .- -.
Post #107083 13th Feb 2012 12:37pm
daveo
what mav unit is it, mk4 or the denso, 2004/5 is right on the switch over, it uses ibus and canbus V8 facelift Range Rover Autobiography 22" wheels.
Post #107143 13th Feb 2012 6:17pm
bergxu
This is a pic of my NAV screen in my NAS '05 FFRR and the one which the firmware upload cured...
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Cheers,
Aaron
Post #107230 14th Feb 2012 2:39am
gliciouz
Just bought my `04 Vogue 2 weeks ago. Cd changer was acting a little weird and cds would not always play and magazine would get stuck some times while loading. Sorted after keeping the car off for a few mins then turning on but yesterday touch screen went blank with HLDF CAN BOOTLOADER message. I see people have success sorting this using update dvd.
Wondering if anyone has the software and could be helpful in this matter?
Post #187387 9th May 2013 11:42am
i think that this 'HLDF CAN BOOTLOADER' firmware is available from a disco3 member on the disco3 forum.. ... - .- -.
Post #187388 9th May 2013 11:50am
