Home > Technical (L322) > TD6 RE NEW TYPE OF CRANKCASE BREATHER
AKIS
2004 Range Rover Vogue Td6 Cairns Blue
Good day Mark and thanks.So BMW part nr of new type crankcase breather for td6 11127799224.
Thanks to all for the assistance.
Post #106526 10th Feb 2012 10:17am
Shaun
England 2011 Range Rover Vogue 4.4 V8 Orkney Grey
Part number 11127799225 seems to be listed for the BMW M57 and 1127799366 for the Vortex unit by itself.
Post #106541 10th Feb 2012 11:10am
AKIS
Hi shaun.Have seen pn 11127799225 fr m57n while td6 is m57 and really donot know the differences other than the cc.
Others saying that TD6 has the exact same filter/housing with TD4.From various forums on TD4 is fitted the 11127799224.
But now more confused.
Believe only a guy who has replaced the old type filter/housing with the new one will be able to give the correct pn.Hope that will read threat and reply
Post #106583 10th Feb 2012 1:21pm
mjdronfield
Chaps,
I did just the filter swap for the vortex cone.
From Stratstone BMW, part number 11127799367 "Oil Seperator"
It was £23.35 inc VAT.
Dropped straight in.
Just the "filter" though, not the entire unit, but you don't have to change the entire unit if you don't want to.
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #106590 10th Feb 2012 1:45pm
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
I bought this engine that is specific to M57 of 3000 diesel http://www.ebay.it/itm/250767686422?ssPage...1127799367 is the code for the engine type m47
Post #106760 11th Feb 2012 8:56am
mjdronfield
The M47 is the BMW 2.0D, as fitted to the Td4 Freelander and 320d etc.
I understnd the same breather unit fits the M57 engines as well.
It should fit. I only did the filter part.
Hope this helps.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #106765 11th Feb 2012 9:21am
AKIS
Bought the new vortex type breather 11127799224.Housing is ok but oil sepertor doesnot fit on TD6.Oil separator has a cap on top left side while said gap should be in the middle order fit.Obviously if u want to buy oil separator 11127799367 with housing the correct part nr is not the one ending to "224"
Anyway since i had it in my hands i made a new small gap to the right position and fitted it but there was black smoke during accelaration so returned back to the old type.
Post #109907 28th Feb 2012 12:47pm
