Home > Technical (L322) > Fuel gun keep clicking when refuelling *
Page 2 of 3 <123>
Observe:
Below is the fuel filler neck on my Defender: A big bore open pipe where fuel can gush in at any speed. Lovely.
Below is the TDV8 filler neck. Note the small bore of the pipe but also, the misfuel device is NOT triggered, but further impedes the nozzle. When I fill up, the nozzle is half way out of the neck - why design this SO badly?
Note also that despite the filler neck all having been replaced a year ago, the rubber has perished thanks to dripping diesel - which is because its such a crap fit and always splashes back out when full, because the nozzle won't go all the way in! Censored Censored Censored Censored
I bet some of you think the misfuel guard has been triggered but I just checked it with the yellow plastic reset tool and its down as far as it will go. (Unless mine is just bolloxd)
 Discovery 4 HSE
Post #104993 2nd Feb 2012 3:42pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
RRUK wrote:
Observe:
I think there may be an issue with your misfuel guard as I cant see mine when it is reset, your looks partially triggered to me Confused 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #105081 2nd Feb 2012 8:47pm
Afraid so Adam, looks like you're only half cocked Laughing Laughing Laughing
Post #105084 2nd Feb 2012 8:49pm
As above i set the one off in a D4 when filling from jerrys and that looks partially on... take it back under warranty and get a proper fix done and compare it while your there as thats not right Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #105088 2nd Feb 2012 8:58pm
Its not under warranty! Big Cry Big Cry Discovery 4 HSE
Post #105107 2nd Feb 2012 9:53pm
Can someone post a similar picture of theirs please? Discovery 4 HSE
Post #105108 2nd Feb 2012 9:53pm
Also, if you open up the picture of mine full size and zoom into the spout, there are 2 pegs on either side of the filler neck, and these are what prevents the fuel nozzle going further in. Is everyone's like this?
I bet if I tried putting an unleaded spout down there it would bl00dy fit! Discovery 4 HSE
Post #105109 2nd Feb 2012 9:55pm
I've just zoomed in and its certainly in the UP or partial up as its displaying the handbook 'I' which shouldn't be seen.
When you put the tool in does it click at all as IIRC you put it in and pull it back a little and it flaps down i think... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #105114 2nd Feb 2012 10:04pm
Andy_J
I had a similar problem with my TDV8 when i got it a couple of month ago, I found the reset tool got the misfuel device to the point you have there. I found I had to put something down (3ft socket extension bar is what I used) the fuel filler to give the yellow bit a light shove and it down clicked out of sight 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #105120 2nd Feb 2012 10:32pm
Shocked
Bloody long filler neck then......
Post #105133 2nd Feb 2012 11:34pm
Andy_J
Laughing only thing I had to hand to fit, you only need a bar about 12" long 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #105134 2nd Feb 2012 11:42pm
I'm going to give this a go, its annoying me now, shame its so damned cold outside, hate this time of year for working on cars. Wish I had a fully heated garage with ramps and free tools for every job imaginable Cool Discovery 4 HSE
Post #105883 7th Feb 2012 2:13pm
You need a garage like member 47p2 has Adam �.. Thumbs Up the wife's got my double garage full of junk , what is it with women and " Just put it in the Garage " �. Censored Censored Censored
Post #105885 7th Feb 2012 2:26pm
The heater's on in the garage today, toasty at about 15�C at the moment. Yesterday was spent working on the Viano changing a broken spring caused by a fookin pothole. I changed both springs both drop links and ARB bushes.
Post #105886 7th Feb 2012 2:30pm
sounds like you live in heaven john..... Bow down ... - .- -.
Post #105888 7th Feb 2012 2:34pm
Page 2 of 3 <123>
