Home > Maintenance & Mods (L322) > Help! Failed Steering Wheel Change |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
I've been an impatient putz!
27th Jan 2012 7:03pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Can't help with the first part (which video?), but second part is normal after battery disconnect.
27th Jan 2012 7:05pm |
That's a relief.
27th Jan 2012 7:11pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
there is a nack to removing the air bag, i use a allen key just a bit smaller then the hole.as you push in the nack is to push down on the air bag at the end you are doing,it may not spring up first time so go on to the other side and do the same ..it will spring up..dont worry about the sus fault it will clear its self, done it on my car just the same.. V8 facelift Range Rover Autobiography 22" wheels.
27th Jan 2012 7:17pm |
Gents, as always, a massive thanks!
27th Jan 2012 7:21pm |
An update to this:
29th Jan 2012 4:31pm |
SuperlightR Member Since: 27 Jan 2012 Location: Sussex Posts: 13 |
looks good. |
29th Jan 2012 6:21pm |
