![]() | Home > General > Poor MPG with TDV8 |
When was it last serviced ? Could be filter related/ quality quantity of oil?
Have you tried a decent run of booting it hard and really clear it out?
Johnh Member Since: 07 Nov 2011 Location: Rugby Posts: 44 ![]() ![]() ![]() |
I also have disappointing MPG averaging 22.5 for the last 1000 miles including a trip to wales towing a small trailer, I would of expected close to 26-28 MPG.
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 ![]() ![]() |
I'm pleased to report that I am still returning 30+mpg after 12,000 miles with no change. However, most of my driving is long distance motorway 60-70ish |
Bomber County Member Since: 12 Dec 2011 Location: Dunston, Lincoln Posts: 81 ![]() ![]() ![]() |
same for me as AMD.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35510 ![]() ![]() |
i'm a lowly td6 owner and i get 590 on a tank which aint bad for a tractor engine.. ... - .- -.
Same as scarey i get no less than 19-20 around town and at least 24 on a fast run.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1424 ![]() ![]() |
I'm a firm believer that engines from time to time need a bit of a blow out ... especially diesels. By that I mean that you rag it a little ( boot it hard from the roundabouts, accelerate hard up to speed and hold lower gears longer ) I used to throw injector cleaner into a tank of the V6 diesel passat and then drive it hard and it seemed better for it. Over time, things do bung up a little. and a decent work out for the engine can clear the system out.
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
"590 on a tank" - I'm impressed and usually happy with anything over 500 ! |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Thanks for all the replies sent.
I should have stated that my car is a 2006 3.6 TDV8 Vogue |
carlos50 Member Since: 03 Feb 2011 Location: North England Posts: 717 ![]() ![]() ![]() |
I have a late 06 TDV8 and have found the same, i get about 24 mpg combined with motorway, country lane and town. I had mine mapped using the Superchips Bluefin and it goes very well but no mpg improvement.
that was on one journey from swindon to brussels and back so mostly motorway.. ... - .- -. Y. O. L. O. . |
Badger Member Since: 02 Jan 2011 Location: Bucks Posts: 170 ![]() ![]() ![]() |
I have used DMS to re-map a 3.6 Tdv8 and two 4.4 Tdv8s and the results are stunning in terms of extra torque, power, smoothness and extra MPG. I get a consistent 31mpg from the current one. From memory i got 28 from the 3.6.
