Home > Technical (L322) > air suspension troubles |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Funny you didn't get any errors with it. Mine shut down the air suspension altogether when I got a hole in the front. Useful info for others though should the same fate befall them. .
17th Jan 2012 4:59pm |
Fr_Raf Member Since: 20 Nov 2010 Location: Lyon - Paris Posts: 147 |
I think I have the same problem for Two or three days...
17th Jan 2012 8:22pm |
It's really not that difficult to change the front air susp strut yourself. Check my howto on the wiki. .
17th Jan 2012 10:22pm |
I read it several times, thank for all your DIY, they all are very wellcome
18th Jan 2012 12:00am |
Easiest way to check:
18th Jan 2012 1:52am |
Thank you, i'll try that, but what is very bizarre, is that the car rised to the normal height, and to the off road height, and stayed for about one hour without leak... |
18th Jan 2012 3:08am |
Mine only evidenced itself when I put it into off road height using All Comms to reset. before that the leak was protected by the sides of the airbag. You might have to do some "lifting" of the wheel arch to get it hissing? Doesn't sound like a leak at the airline joint to the strut, but it could be at the valve behind the wheelarch liner. Play with it with the window down and the door closed (so you can operate the switch and the air susp remains active) .
18th Jan 2012 10:04am |
Many thanks,
18th Jan 2012 4:50pm |
nice to read that Reformed,
19th Jan 2012 4:15pm |
ben2012 Member Since: 10 Jan 2011 Location: West Yorkshire Posts: 54 |
Might be a long shot and I'm trying to remember back sometime but I seem to recall a similar problem on my 2005 td6, can't remember the exact faults it was showing up but it all turned out to be the silencer on the exhaust on the compressor blocked so not allowing it to work correctly, apparently on the newer models they modified this part, when Landrover assist came out the chap just twisted/snapped off the brass snapped part and it cured it, although it did make the compressor slightly more noisy. Cheers Ben |
19th Jan 2012 7:13pm |
