Home > Technical (L322) > Warn Receiver Shackle
Deep Down
France 2003 Range Rover Vogue Td6 Adriatic Blue
Has anyone used one of these with standard RR tow bar armature? I'm sure I've seen one in someones photos but can't seem to find it again.
http://www.extreme4x4.co.uk/acatalog/WARN_RECEIVER_SHACKLES.html
Post #101744 14th Jan 2012 8:59pm
Vogue
yes, but not at £56, that a f1lucking joke!
Assembled ours from hardware from the local agricultural merchants for the shoot vehicles. The LR experience L322's also have them fitted.
Post #101746 14th Jan 2012 9:13pm
Deep Down
That's more along the lines that I was thinking, a bit of DIY, will see what they have in stock on Monday.
Post #101747 14th Jan 2012 9:19pm
Vogue
just to give an indication mine, cost around £6 for the shackle (load rated too) and £11 for the receiver bracket - the receiver bracket is just mild steel bar stock with a couple of holes drilled throgh it, 1 for the hitch receiver pin and the other for the shackle - I would have had one made in the workshop but at £11 not worth the bother - it was 18 months ago though!
There were also some listed on the ebay US site a while back as the receiver brackets are standard over in the states for SUV tow bars and quads
Post #101749 14th Jan 2012 9:23pm
I just use a rated shackle for about 7tonne that fits nicely once bolted up over a standard tow hitch. Machinemart I think I got it from for about £7 Smile
Post #101753 14th Jan 2012 9:37pm
Vogue
here you go £12, the delivery kills it, but yoiu get the general idea, there are loads of them listed on ebay US
http://www.ebay.co.uk/itm/2-Hitch-Receiver...2eb4005cf6
Post #101755 14th Jan 2012 9:53pm
I've got a couple - they work well.
I also have a Jeep Wrangler with a 2" reciever so I have 1 on that & one on the RR
Got them from the US when I was shipping a load of Jeep bits - they were around $20 IIRC
Post #101769 14th Jan 2012 11:40pm
Not quite US prices, but slightly cheaper here - http://www.arbilrecoverygear.co.uk/product...acket.html
Post #101770 15th Jan 2012 12:01am
the 2'' square hole that the fullfat has also happens to be the standard american tow hitch size...there are a few tow hitchs on ebay that will fit and they are alot cheaper than the OE landrover ones.. ... - .- -.
Post #101792 15th Jan 2012 11:26am
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I hink it was mine you might of seen , i got mine from devon 4x4 it was about £60 but i cant remember onto no6 Range Rover
Everyone needs a hobby
Post #101795 15th Jan 2012 11:48am
Be careful though as in my experience, most don't fit....
The RR receiver seems to be slightly smaller than the one on my Jeep - I have 3 different drawbars like this & whilst they are all very close none of them will actually fit - http://www.me.ford.com/servlet/Satellite?c...ry-overlay
The RR parts are a much tighter tolerance and don't rattle as much as the Jeep does. Though with a pin rather than a bolt, there is still some play & therefore rattle, but I like to be able to remove mine, so stick with the pin.
Also the receiver on the RR is buried quite a long way under the bumper - the RR parts are longer & made of solid bar, whereas the US ones are typically hollow square section & whilst you can get extenders, I would be much happier with the solid bar.
Both of the shackle adapters fitted when they were new, but the one off the Jeep has some surface corrosion on it now & will no longer fit all the way into the RR receiver, but fits the Jeep no problem.
Post #101813 15th Jan 2012 1:41pm
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
Are the US ones not 2" and the UK 50mm, I am sure this is the case with actual tow balls 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #101836 15th Jan 2012 4:28pm
Deep Down
I think it was as I remember the winch as well.
It's something to have as a just incase I need to be pulled out, or need to assist others, better ground clearance with one of these than the tow ball.
There are a lot of choices around. If I can't find some 50mm or 2" stock next week to make my own I'll get one off the shelf.
Thanks for all the input Thumbs Up
Post #101837 15th Jan 2012 4:59pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
On the subject of winching, I would like to add a little bit of input.
Remember that any winch has a maximum pull, and any equipment supplied with the winch such as rope and hook etc. will generally be rated at a higher breaking strain than the winch can pull. This means that generally any failures are caused by something "added" in the pull, such as anchor points, strops, shackles etc.
Most people are aware of "ground factors" which is the amount of resistance the surface has. E.g. It is easier to pull a vehicle on hard standing than soft ground. However many people do not realise that if a vehice is actually buried half way to the axles in clay/mud, the factor increases massively to up to 3 times the weight of the vehice being towed.
So, with these things bearing in mind, remember that an FF weighs close to 3 ton. So make sure any shackle used is rated to at least 10 tons. If you can, always use a bow shackle rather than a D shackle. Also check that wherever you are going to attach a winch to a vehicle being recovered is a part of the vehicle that will withstand the actual pull.
BTW, I am a winch instructor with the Fire Service. If anyone wants to know more about winching, just ask.
Regards
Mike No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #101847 15th Jan 2012 6:52pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
If you check Microcat, the US spec armature is 52mm, whilst the Euro spec is 50mm...... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #101853 15th Jan 2012 7:25pm
