Home > In Car Electronics (L322) > Aux socket problems |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3836 |
9th Jan 2012 1:01pm |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 |
Re shutting . Mine doesn't stay shut either. If you take the bottom left side vent by the rear passengers feet off (easy clips on/off) you can see the mechanism which is pretty flimsy. Mine clearly had a part of it snapped off when forced previously (presumably)?
9th Jan 2012 4:08pm |
Just use two well placed bits of velcro on the inside lip and it stays shut , anyone in the back is none the wiser |
9th Jan 2012 5:34pm |
Excellent thanks.
10th Jan 2012 9:32am |
356pilot Member Since: 31 Dec 2010 Location: Peak District Posts: 16 |
Oh - also - while you've got that lower vent panel off, there are two larger torx screws which become visible (one on each side) which I believe would probably allow you to remove the whole rear panel and get at the lid mechanism. Haven't tested that theory though. |
10th Jan 2012 9:37am |
I'll post again before I start the work then if I get stuck in the car and no ones heard from me after a few days Martin can organise a rescue party Geoff |
10th Jan 2012 10:09am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Was wondering where you had gone Geoff. Sorry to hear about your job. Present :2008 TDV8 HSE
10th Jan 2012 12:27pm |
Job Done
11th Jan 2012 11:31am |
Excellent! Love it when a plan comes together.... |
12th Jan 2012 9:01pm |
