![]() | Home > Maintenance & Mods (L322) > Damped opening of lower tailgate |
If you place the bracket on the lower boot and leave an equal gap around the outside, look at the picture on the first page of this thread (it will all become clear when you line it up) then drill the top hole and fit a screw. Then close the boot half way and you can get to the drilling angle easily... Hope this helps...
myvatn Member Since: 20 Oct 2010 Location: Munich Posts: 80 ![]() ![]() ![]() |
do you have a part number? I searched the numbers for the damper mountings etc. in RAVE LR017455 1 LIFT - GAS, RH SIDE ONLY, LOWER TAILGATE LR017590 1 BRACKET, RH SIDE ONLY, LOWER TAILGATE \ LR020219 1 BRACKET, RH SIDE ONLY, LOWER TAILGATE >> dont know the difference between this three parts LR021053 1 BRACKET, RH SIDE ONLY, LOWER TAILGATE / LR003808 2 SCREW, M6 X 16MM, TORX, BRACKET, HEX HEAD, LOWER TAILGATE LR017461 1 STRAP - CABLE, RH, LOWER TAILGATE |
sidmini Member Since: 20 Sep 2010 Location: kent Posts: 45 ![]() ![]() ![]() |
Dan @ Duckworths - could you please verify the parts required for this mod and perhaps package us up a price please? thanks |
I have no idea what screws/bolts Land Rover use to fix them with... We use our own fixings...
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
LR021053 bracket
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
this might help re the button cover..
and its a whopping £1.00+VAT from myself |
Cam-Tech-Craig - thanks for the information but still a query in my head. The parts thats Dan refers to are m6 x16mm screws to secure the bracket to the lower tailgate but surely this only applies to the pre-drilled lower tailgates provided by the factory for 2010 > models? If that is the case I will need a screw that will securely hold the bracket in place..which screws to you use, could you take a photo for us? thanks!
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
I've never taken the trim card off, but I bet you could get your hand in and fit a nut to the inside where the bolt passes through? Someone might be able to confirm this 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
I've taken. The cover on mine off many times |
Kingpleb - how do you take the cover off please? |
1. Open upper tailgate.
Thanks very useful info kingpleb! |
