Home > Technical (L322) > Front suspension thump
Page 6 of 8 <12345678>
only a thought but its not something obvious like a loose spare etc and the noise is being transmitted to the front.. ... - .- -.
Post #98660 21st Dec 2011 4:03pm
Glideman
Location: Stood next to a broken down Range Rover in Darwen
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
It's not the spare, took that out when it needed a new suspension compressor 2 weeks ago Thumbs Up It sounds to everyone who's been in it like the left front suspension which is almost all new Confused
So far done . . .
rear top & bottom hub bushes
both anti roll bar drop links
left suspension strut
left suspension arm (the one with the sensor attached)
left rear trailing arm & bush
2 new rear wheels complete with tires
suspension pump
removed the battery & checked under it for anything loose
removed both front wheel arch covers
been round all the suspension with a crow bar on a ramp at three separate garages including a main dealer
I've been working on cars for over 20 years & never come across a problem that can't be fixed like this, complete mystery to me.
still knocking
 Range Rover 4.4 V8 Vogue
Post #98674 21st Dec 2011 6:06pm
ric355
I suggested ARB bushes earlier but having looked at Rave I see they are not actually replaceable - they are bonded to the ARB and are not listed as a separate part !
Post #98677 21st Dec 2011 6:40pm
fisha
although the armoured RR version seems like it has seperate bushes available which I thought was odd. V8 or else ...
Post #98683 21st Dec 2011 7:42pm
Glideman
Yes the ARB bushes could cause this noise as the force transmitted from the drop links would make noise that sounded multiple times with one strike, seems logical? Only problem is how can they be replaced? Would the engine need to be dropped with the sub-frame or can it be threaded through the wheel arch, seems as though a few of us have this noise so it may be worth a try. . . . . Range Rover 4.4 V8 Vogue
Post #98731 21st Dec 2011 9:51pm
ric355
But as mentioned, they are not replaceable unless you have the armoured version. You would have to buy a new ARB. Rave says drop the sub frame to replace the ARB.
Post #98765 21st Dec 2011 10:13pm
rads
2005 Range Rover Vogue SE Supercharged Tonga Green
As mentioned above, removing a drop link should confirm or eliminate the ARB. Definately worth a shot before spending money or serious time removing the sub frame.
(Still think it is the rack).
David
Post #98773 21st Dec 2011 10:32pm
rads
OSF strut changed yesterday (serious leak on airbag).
Still knocking.
David
Post #99318 24th Dec 2011 6:32pm
Glideman
Oh Censored Rolling Eyes Have a good Christmas David Very Happy Range Rover 4.4 V8 Vogue
Post #99319 24th Dec 2011 6:35pm
AndrewT
New Zealand 2003 Range Rover Vogue 4.4 V8 Oslo Blue
This is a really long shot but I had a similar problem and it turned out that one of the plastic clips on the headlight had snapped so the light was slightly loose and it made a loud knocking noise which was probably amplified by the wing. I was convinced it was coming from the suspension. Give the headlight a good shake and see what happens.
Post #100240 4th Jan 2012 7:41am
rads
I love this type of suggestion, will now be feeling upbeat and optimistic all day until I can get out and have a look at the headlight later this evening.
You know, I think I have seen a slight shake in the headlamp beam over rough roads, had put it down to some looseness in the leveling, beam bending gizmos.
Fingers crossed, will update later.
David
Post #100242 4th Jan 2012 8:21am
AndrewT
Hope it works.
On a related note does anyone know where I can get a scissor type balljoint splinter that is wide enough to fit? I don't like the fork type as they do too much damage but dont want to pay for the Land Rover genuine tool.
Post #100244 4th Jan 2012 8:32am
rads
Can't help I'm afraid.
Since I was changing the joints I accepted that the old ones would be scrapped and used a fork type.
David
Post #100246 4th Jan 2012 8:36am
Glideman
Just had a look at mine. I did remove the light to replace the washer motor, it's all solid. As mine only started after fitting a Dunlop air strut I'm thinking of replacing it with a Delphi one. No doubt the other side will go soon and if the knock is still there I can keep it for a spare Rolling Eyes
I used a fork type ball joint splitter & had no problems getting it off, shouldn't damage anything if your careful. Cost about £5 from Machine Mart Range Rover 4.4 V8 Vogue
Post #100402 5th Jan 2012 12:41pm
rads
Struts are handed Sad
Don't forget, mine has had a new pair of Delphi struts and still knocks.
Plan to try removing one drop link tonight, and have a good look at the headlight.
Have also booked it into my local indy for a bit of a poke around early next week.
David
Post #100408 5th Jan 2012 1:30pm
