Home > Technical (L322) > Coasted to a halt, wont start
900ssduke
New to the forum and FFRR. I have just bought an 06 TDV8 Vogue SE. Had a few issues with flat batteries this past week. Today I set off, got a warning message about the transmission, went into "safe mode". I coasted onto the verge and the engine died. It turned over briefly before the battery went flat. Got a battery booster on to it, engine turns over but wont start, seems like no diesel getting to it. pulled a couple of pipes off the top of the fuel filter and no fuel there. Looked at some fuses in the rear quarter and they seem ok. Cycled the locks a few times but still no start.
Any ideas?
Post #107297 14th Feb 2012 12:14pm
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Always difficult to diagnose remotely!
Got fuel in the tank? Fuses all Good? Battery is next - famously causes trouble if it's duff!
On the bright side, if you have a Ducati you are already used to this sort of behavior from your vehicles and have a good breakdown recovery service on stand-by!
Post #107310 14th Feb 2012 1:32pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Fuel pump?
Post #107323 14th Feb 2012 2:34pm
900ssduke
Fitted new battery this morning, still not winning. Fault code PO501 vehicle speed sensor range / performance. Car still will not start like its getting no fuel. Old Ducati electrics can usually be fixed with a scotch block connector and a whizz of wd40, wish this was in the same place.
Post #107480 15th Feb 2012 9:52am
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
How much fuel do you have in your tank?
Remember reading something on here about when it gets to a 1/4 - 1/8 full no fuel gets to the engin because a float switch Confused isnt working.
Try searching for that Very Happy
Post #107670 16th Feb 2012 8:06pm
chrisc
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Had similar issue with my 2005 TD6. After running perfectly car refused to start. Turned out to be no fuel coming through due to faulty fuel pump relay on fusebox - a few quid and 2 minute fix. With any luck your problem may be the same.
Post #107863 17th Feb 2012 9:10pm
L4FLIROP
United States 2003 Range Rover HSE 4.4 V8 Adriatic Blue
Most likely your fuel pump in the tank has died.
Post #107884 18th Feb 2012 4:54am
900ssduke
Back on the road again. The new battery I was supplied was also a dud, so I ended up chasing my tail. Another new battery fitted and all is well (today)
Post #107914 18th Feb 2012 10:51am
