Home > Technical (L322) > Coasted to a halt, wont start |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
Always difficult to diagnose remotely!
14th Feb 2012 2:32pm |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1496 |
Fuel pump? |
14th Feb 2012 3:34pm |
900ssduke Member Since: 22 Jan 2012 Location: Aberdeenshire Posts: 3 |
Fitted new battery this morning, still not winning. Fault code PO501 vehicle speed sensor range / performance. Car still will not start like its getting no fuel. Old Ducati electrics can usually be fixed with a scotch block connector and a whizz of wd40, wish this was in the same place. |
15th Feb 2012 10:52am |
Bob the B Member Since: 10 Jun 2011 Location: Newcastle upon Tyne Posts: 163 |
How much fuel do you have in your tank?
16th Feb 2012 9:06pm |
chrisc Member Since: 20 Jul 2011 Location: Loughborough Posts: 6 |
Had similar issue with my 2005 TD6. After running perfectly car refused to start. Turned out to be no fuel coming through due to faulty fuel pump relay on fusebox - a few quid and 2 minute fix. With any luck your problem may be the same. |
17th Feb 2012 10:10pm |
L4FLIROP Member Since: 03 Feb 2012 Location: Washington DC Posts: 3 |
Most likely your fuel pump in the tank has died. |
18th Feb 2012 5:54am |
Back on the road again. The new battery I was supplied was also a dud, so I ended up chasing my tail. Another new battery fitted and all is well (today) |
18th Feb 2012 11:51am |
