Home > Maintenance & Mods (L322) > Rear washer leak repair - the cheaper option!
Page 2 of 6 <123456>
or Lazy
or un-talented! Discovery 4 HSE
Post #107748 17th Feb 2012 11:51am
Delete as applicable! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #107812 17th Feb 2012 4:22pm
Thanks fella this worked a treat today Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #109817 27th Feb 2012 11:38pm
Post #109835 28th Feb 2012 12:48am
alan
2002 Range Rover Vogue Td6 Alveston Red
Just put the seal in mine as it started to leak after i cleaned the line out and replaced the NRV. You dont have to remove the spoiler/wiper arm to do this repair just remove the 3 30 torx mounting bolts and the 7 15 torx screws it only takes about 20 minutes Thumbs Up
Post #177165 12th Mar 2013 3:17pm
MrP
England 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
Took mine apart at the weekend and yep full of brown gunk - cleaned it all out - refitted it then snapped the top off the wiper arm spindle Evil or Very Mad Got so fed up with it (and it was only ever going to be a temporary repair) that I followed RRUK's advise - Dan has yet more of my hard earned folding stuff and as of tomorrow I should have a nice new wiper motor Very Happy "On first name terms with my local Dealer......now."
'61 Plate 5.0SC Autobiography - in Black ——— Gone
'53 plate 4.4V8 Vogue Bonatti Grey inside and out. ----- Gone
Post #177192 12th Mar 2013 5:10pm
supershuttle
Remember to bolt the spoiler back in place as if you don't this becomes a very expensive mod Thumbs Up Thumbs Up
BTW I had to use two washers to get a seal the old one on top of the new one but it works fine Very Happy Geoff
Post #177194 12th Mar 2013 5:44pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
I replaced my non return valve but even now if I've not used it for a bit it still takes a while for any water to come through......then its OK until left for a while....... Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #177798 15th Mar 2013 8:30pm
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
I think I have this same problem. Got back from a trip last night in my FF after using the rear washer (never used before) and noticed yellow fluid running down the inside rear window and sitting on my parcel shelf (this would be the washer fluid).
�185.50 from my local Land Rover dealer so I don't think I'll go that route at the moment.
So I am looking at doing this job, is this the correct oil seal to use as I can't find the one you referenced exactly;
http://www.ebay.co.uk/itm/Rubber-Metric-Ro...2edd78bfe8
I see Alan mentions;
Looking at the article, not sure if this is possible? Is it?
Post #314494 23rd Feb 2015 5:02pm
I would take the spoiler off, makes life sooooo much easier . If it's been leaking, the chances are the motor assembly will be filled with brown, slimy greasy stuff that could go all over the inside of the car.
3 bolts and the spoiler's off, so it's probably the easiest bit of the repair but hey, it's your call in the end, I know what I would do though Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #314501 23rd Feb 2015 6:09pm
scwilson
Thanks. I don't mind taking the spoiler off, it's whether I need to remove the wiper arm from the spindle or not. After recently fitting a new one and the previous one I removed and binned being badly corroded, I would ideally prefer not to have to take the newly fitted arm off the spline again.
I am realizing the less I mess the better Smile
Is it necessary to remove the wiper arm and would any oil seal fit as long as it is those dimensions you specify?
Post #314503 23rd Feb 2015 6:13pm
If you're going to take the motor out to work on it (preferred) you need to take the wiper arm off the spindle first. If you've recently replaced it, it should come off much easier.
As long as you get one to the spec on the link, you should be fine. Got - 2017 SDV8 Autobiography in Loire Blue
Post #314507 23rd Feb 2015 6:35pm
^ yep will come off a treat now if it's been off recently. So much easier to work on the mechanism on the kitchen table👍 There is nothing that can't be fixed with a hammer😜😜
Post #314522 23rd Feb 2015 8:32pm
scwilson
ok thanks chaps. I'll need to find a day when it's dry to do this job.
Post #314547 24th Feb 2015 12:40am
scwilson
This is the seal I have just purchased;
http://www.ebay.co.uk/itm/400394972383?_tr...EBIDX%3AIT
These are the screws;
http://www.ebay.co.uk/itm/150963958027?_tr...EBIDX%3AIT
Post #314594 24th Feb 2015 12:26pm
