![]() | Home > In Car Electronics (L322) > Which Sat nav mk3/4? |
welsh19 Member Since: 19 Jan 2012 Location: Swansea Posts: 17 ![]() ![]() ![]() |
So,
sorry its a 2005 HSE touchscreen 2005 RR HSE 2.9 TD6 Auto |
Touchscreen is neither mkiii or iv. The touchscreen system uses the Denso nav computer. Check the pic in the Can you please identify the items for me? thread. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
there's also some info re the denso unit in the wiki... ... - .- -.
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 ![]() ![]() ![]() |
but you will be pleased to know you can pick them up for far less then you would pay for a MK4 unit, ebay is the place unless someone has one on here... V8 facelift Range Rover Autobiography 22" wheels.
Ah brilliant thanks for the info, if anyone does have one to sell please message me I'll gladly see if I can take it off your hands, but other than that I'll keep a look out on eBay!
I might be missing some thing here but if your touch screen works at the moment then your MOST system doesn't have the loom for Sat Nav and your car won't be configured for it . I might be wrong of course but does your car have an empty cradle and a bunch of lose connectors ? 2008 MY Supercharged
Yes it does have an empty cradle and loose connecters, I'm put ATM the moment in
ok here is the picture of the rear compartment and the front touch screen
Well I think it helps you because it looks like you need a nav unit from a Disco 3 , SSRR or a RR 2006-2009.
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 ![]() ![]() ![]() |
I think Axle is correct that if the MOT network is broken nothing works. looking at your picture it appears that there is not TV Tuner and the cables you show are the power and ariel cable for that item, although you should have two of the cables with the double black wire?
re the MOST network, this from the denso info on the wiki might help...
See a second double black wire but they were tucked right back so there could well be another, the Bluetooth module was also stuck Down the bottom of the compartment,
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 ![]() ![]() |
Look at the SC boot picture i posted the other day as that might help. all smug in my new plug!
