Home > In Car Electronics (L322) > Which Sat nav mk3/4? |
welsh19 Member Since: 19 Jan 2012 Location: Swansea Posts: 17 |
So,
22nd Jan 2012 5:14pm |
sorry its a 2005 HSE touchscreen 2005 RR HSE 2.9 TD6 Auto |
22nd Jan 2012 6:02pm |
Touchscreen is neither mkiii or iv. The touchscreen system uses the Denso nav computer. Check the pic in the Can you please identify the items for me? thread.
22nd Jan 2012 6:19pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
there's also some info re the denso unit in the wiki... ... - .- -.
22nd Jan 2012 6:41pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
but you will be pleased to know you can pick them up for far less then you would pay for a MK4 unit, ebay is the place unless someone has one on here... V8 facelift Range Rover Autobiography 22" wheels.
22nd Jan 2012 10:27pm |
Ah brilliant thanks for the info, if anyone does have one to sell please message me I'll gladly see if I can take it off your hands, but other than that I'll keep a look out on eBay!
22nd Jan 2012 10:48pm |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I might be missing some thing here but if your touch screen works at the moment then your MOST system doesn't have the loom for Sat Nav and your car won't be configured for it . I might be wrong of course but does your car have an empty cradle and a bunch of lose connectors ? 2008 MY Supercharged
23rd Jan 2012 8:58am |
Yes it does have an empty cradle and loose connecters, I'm put ATM the moment in
23rd Jan 2012 2:01pm |
ok here is the picture of the rear compartment and the front touch screen
23rd Jan 2012 4:31pm |
Well I think it helps you because it looks like you need a nav unit from a Disco 3 , SSRR or a RR 2006-2009.
23rd Jan 2012 4:35pm |
Renegade2 Member Since: 03 Dec 2011 Location: Cardiff Posts: 134 |
I think Axle is correct that if the MOT network is broken nothing works. looking at your picture it appears that there is not TV Tuner and the cables you show are the power and ariel cable for that item, although you should have two of the cables with the double black wire?
26th Jan 2012 11:07pm |
re the MOST network, this from the denso info on the wiki might help...
27th Jan 2012 8:03am |
See a second double black wire but they were tucked right back so there could well be another, the Bluetooth module was also stuck Down the bottom of the compartment,
27th Jan 2012 1:01pm |
CUE99T Member Since: 02 Oct 2011 Location: Glasgow Posts: 779 |
Look at the SC boot picture i posted the other day as that might help. all smug in my new plug!
28th Jan 2012 1:24am |
