Home > Technical (L322) > rain sensing wipers
Page 1 of 3 123>
Andy
rain sensing wipers
Am I right in thinking that to activate this feature, you put the wipers on intermittent? If so, mine still wipe the screen when bone dry. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #6906 12th Aug 2009 11:04pm
That can happen if there is a build up of dirt or dust on the windscreen sensor
Post #6908 13th Aug 2009 8:41am
dan_uk_1984
Mine always does an initial wipe, even if the screen is dry when you first turn them on, I think that's normal. TestBook can query it to make sure it's working correctly.
Post #6909 13th Aug 2009 11:24am
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Have you had the windscreen replaced recently? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #6912 13th Aug 2009 4:22pm
Andy
I haven't, and it appears to be the original one. It needs replacing though as it's scratched and chipped. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #6913 13th Aug 2009 6:23pm
Andy
If they sense rain, shouldn't that be something that doesn't need activating? Whats the point. They should come on automatically, not have to be switched on! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #7017 22nd Aug 2009 9:21am
JW911
They have to be reset when you start the ignition. The main reason being for when Americans drive into a car wash, they don't rip the wipers off.
Post #7020 23rd Aug 2009 8:18am
Andy
How are they reset then? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #7021 23rd Aug 2009 9:00am
JW911
Select wipers "off" then "on - intermittent" again.
Post #7022 23rd Aug 2009 11:12am
Andy
Confused That still defeats the object to me- I still say/think the whole point is that they come on automatically, without input from the driver. Yes, I agree you should be able to override it, but it should be on by default, not have to be put into intermittent. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #7023 23rd Aug 2009 2:36pm
nbunney
The reason they are put to Int. is so you can select the sensativity in effect.
Everyone wants their screen cleared at different levels of rain coverage.
Post #7024 23rd Aug 2009 3:08pm
JMC
Disco3 does it properly - once set to intermittent, they work whenever water hits the screen without having to be re-set each time the ignition is cycled. One of the first things I noticed about the FFRR was this apparent need to be told to 'sense' precipitaton each time it starts raining. As you say, it defeats the purpose and I still can't understand why the FFRR isn't working the way the D3 does. Evil or Very Mad The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #7040 23rd Aug 2009 10:09pm
It's a different platform and technology and more importantly, you get your driver to do it. Laughing Discovery 4 HSE
Post #7041 24th Aug 2009 8:16am
Andy
Well, I've found out why they don't work - cos its not fitted to the car!!
i parked next to an 03 vogue yesterday and I could see the sensor on his windscreen was different to mine. It was larger and had a small round sensor in the centre of the black section. Mine hasn't got this.
Doh! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #9598 17th Dec 2009 4:18pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Yes, its a bit annoying having to reset them everytime it starts raining/start the car, but I agree with you, this way you have more control.
How many times have you caught that kind of drizzle that never fully wets the windscreen? You give a swipe and you can't see a thing because it didin't have enough water in it. With the FF system, under those conditions you can drive without the wipers firing off at any drop.
Are we so unwilling to move a hand that we can't turn the system on or off???
But the main thing is that you should not view the system as a ''rain sensing wiper'' but as a ''automatic speed adjustment wiper''. Being conceived this way, you should have it off always, and only on when it starts raining seriously. If you think of it like this, Its perfect.
I seem to dislike a few of the automatic features on newer cars, lane change??? Come on, crappy stuff. no one comes and you must always blink or else you have lights flashing on the mirrors.
Bells and gongs, another one... Just try to use the RR offroad when you're exiting the car a lot....It'll drive you crazy...Put the belt, close the door, get out again, move the branch, enter the car, put the belt, drive 1000yards, take the belt, get out......etc etc...Lucky for me, the dealer told me the way to shut it up, now I just have the red sign on the dash...
Let us have some control on our actions.
Post #9614 17th Dec 2009 9:41pm
Page 1 of 3 123>
