![]() | Home > In Car Electronics (L322) > Is BT on all the time? |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3879 ![]() ![]() ![]() |
I got a Wiggs module which is great, but I have a problem in that it seems to be on all the time so even with the car locked, keys out etc. So if I make a call from my house with the car on the drive BT kicks in and low and behold everything is transferred to the car and the call is effectively over, we can't hear each other.
Thanks Simon,
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
If I'm on a call when I unlock my car, the call transfers immediately to the car which is annoying. However the iPhone interface allows you to easily redirect the call back to the phone's earpiece or speaker, so the call is not lost for long.
Johnh Member Since: 07 Nov 2011 Location: Rugby Posts: 44 ![]() ![]() ![]() |
I have had a replacement module from wiggs, all works well, with the phone auto connecting and phonebook downloading, however on starting all is lost and the screen states "no phone connected" any ideas
Justinp's tip worked for me - just select the Venture Cam then switch to phone and after a second all is well Geoff |
bosch Member Since: 20 Jan 2012 Location: Kent Posts: 18 ![]() ![]() ![]() |
My phone disconnects from the Bluetooth as soon as I turn the ignition off, but I do have major problems re connecting it everytime I get in the car |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35533 ![]() ![]() |
i'd pm wiggs geoff...he's pretty savvay about things like this and if you've just got a module of him ,he'll help even more.. ... - .- -.
PM Wiggs |
Sorry to hijack this post but im having issues with mine also. I have checked my phone so it displays only numbers that are on the phone and removed any numbers on the sim. I have paired and unpaired device but im still getting some numbers duplicated when going through phonebook on bluetooth. |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
Venture cam will take priority over the phone ... Take the camera out of the car for a day and see if the bluetooth issues go away
Cheers Adrian its a HTC |
Stocky Member Since: 13 Oct 2009 Location: New Forest Posts: 142 ![]() ![]() ![]() |
I read somewhere that it takes 20 mins for the RR to go to sleep. That seems correct on mine so I get the car taking over on calls if i'm in BT range during that time. Just have to change the BT source on the iPhone screen. May take longer to sleep if you don't lock the RR each time you park up at home. I know some systems remain on then and drain battery!
Not sure if it is any help but mine goes to sleep in minutes after locking the car. Maybe also because my phone is out of range of the car after locking (usually). Both with Nokia and Samsung (Galaxy S) no issues of "long connectivity".
