Home > In Car Electronics (L322) > Parking sensor connectors and sensor loom to car connector
tomthevet
Scotland 2005 Range Rover Vogue Td6 Tonga Green
Does anyone know if you can buy new sockets to connect to the parking sensors on an 05/6 L322?
I am trying to find ones which can have new wires connected to them instead of connecting to the original wiring supplied by LR (how they imagined that brittle, thin wires would cope is beyond me!).
I have fixed my loom recently but the original wiring is woefully inadequate and I plan on replacing the whole loom with more durable and flexible wiring but the original connectors at the sensors are impossible to rewire. Am not sure about the one connecting to the car itself but any info will be gratefully received.
T
Post #102963 22nd Jan 2012 4:45pm
stenh02
Scotland 2004 Range Rover Vogue 4.4 V8 Rimini Red
Tom,
I recently patched one of my rear parking sensors. But I also dismantled one of the three female connectors that pushes into the actual sensor.
It seemed to pull apart quite easily and the blade type attachment in the 'plug' pulled out easily enough. I didn't need to re-solder on the blade as there was enough wire functioning beyond the plug to get a solder onto and place in a 'jump' over the break.
The loom wire is pretty thin and I did think a new loom maybe the way forward if there are continuous wire breaks.
Grant
Post #102971 22nd Jan 2012 6:05pm
tomthevet
Oh right so did it come apart in a way which would allow you to resolder new thicker wire to the terminals??
Post #102972 22nd Jan 2012 6:13pm
stenh02
The aperture the blade and wire go thru is pretty small and there is a yellow rubberised material at the end of the blade as a 'bung' that the wire passes thru.
I suppose you could solder direct onto the blade and use a small tool to prod the blade back in to the holder. This is what I was looking at when I decided just to patch the wire after I cut it approx 2" from the connector.
It is difficult to explain but the dismantling of the connector is obvious when you have it in your hand (plastic white u shaped bit comes off and allows you to ease the blades and wires out of the connector).
Luckily I didn't take any photos as I was doing it Big Cry
Grant
Post #102986 22nd Jan 2012 7:05pm
tomthevet
Fair enough. You did exactly what I did ie spliced in a new wire up to a few inches from the connector which is why I thought maybe you could rewire the connector itself.
Cheers for your help
T
Post #102994 22nd Jan 2012 7:19pm
tomthevet
I might get a spare loom to play with. Am looking at this:
http://www.ebay.co.uk/itm/ROVER-75-MG-ZT-R...3370dd75f1
and wondering if the loom to car connector might be the same. Or one of the BMW ones:
http://www.ebay.co.uk/itm/BMW-E46-3-SERIES...3370dacd73
T
Post #102999 22nd Jan 2012 7:26pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
It depends what end of the car you rate on about. I believe only the rear sensors are on a separate loom as the fronts for part of the main engine bay loom and cannot be detached from the car without removing the entire thing. The sensor plugs do come apart but i do agree that they are a little on the flimsy side. 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #103363 24th Jan 2012 7:56pm
tomthevet
Its the rear that gives me all the problems which does have a connector but cant for the life of me remember what it looks like
T
Post #103465 25th Jan 2012 1:33pm
